03-03-2013, 01:54 PM | #1 |
Drives: Black Join Date: Jan 2010
Can I vinyl wrap instead of paint interior pieces?
Has anyone wrapped? Pics?
03-03-2013, 01:58 PM | #2 |
Drives: 2013 Camaro 2SS RS Join Date: Jan 2013
sure you can. get some high quality vinyl, a heat gun, and a razor blade.
03-03-2013, 02:14 PM | #3 |
Any trick to rolling edges?
03-03-2013, 02:43 PM | #4 |
chevy pride
ive not done much , but ive learned this , if u doing interior parts. that u have cleaned with silicone cleaning , wash them in dawn dish washing liquid first and let it sit in the water with the dawn for as long as u can . it helps make the stuff stick . but ya a heat gun and another person to help and the stuff is pretty forgiving.
check out ky speeds fb page https://www.facebook.com/kyspeed |
03-04-2013, 12:54 AM | #5 |
Paul
maybe sand off the texture and shoot some filler primer and adhesive promoter on it.
03-04-2013, 01:28 AM | #6 |
Drives: IOM 2010 Camaro 2ss Join Date: Jan 2013
Just a heads up
make sure you use the heat for shrinking not stretching, if you use the heat for stretching, it does have a memory and it will start to shrink and leave bad edges also primer 94 will help it stick in deep concaves and hard areas Use 3M material, if you skimp on bad vinyl it'll get ya in the end. 3M has perforated wrap vinyl and releves bubbles without any poking Dont use water to apply :wink: |
