03-14-2013, 01:35 PM | #1 |
Drives: 2012 2SS 45th Aniversary Edition, Join Date: Mar 2012
Nurburgring Offset Question
Looking at getting Front 20x9 and Rear 20x10 on my stock tires is the correct offset +35.
Thanks. |
03-14-2013, 04:16 PM | #2 |
MIC
Drives: 2012 SSRS 6sp man Blk Join Date: Nov 2009
03-14-2013, 04:20 PM | #3 |
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD Join Date: Jan 2012
I have 35 rear and 20 front.
03-14-2013, 05:23 PM | #4 |
I'm running 20x9 and 20x10 with a 35 offset at all four corners.
03-14-2013, 08:54 PM | #5 |
The sellar said 35 for both 20x9 and 20x10 just checking. He said I could do +20 in the front but I did not want to go that aggressive.
03-14-2013, 09:21 PM | #6 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Ideally using a 10" +35 rear you should have a 9" +20 front to have almost equal stance front and rear. If you use a +35 on the front, it will stick in 13mm more than the back.
Here's a link to a wheel offset calculator you can play with. http://www.1010tires.com/Tools/Wheel-Offset-Calculator I have all 20x10-35 on my car. Here's a side shot that you can get an idea how far a +35 sticks out in the rear.
03-14-2013, 09:58 PM | #7 |
Here's some pics of +35's at all four corners.
03-15-2013, 07:54 AM | #8 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
03-15-2013, 02:45 PM | #9 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
But +35 up front will ultimately allow for a wider front tire. |
03-15-2013, 03:10 PM | #10 | |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
03-15-2013, 03:17 PM | #11 |
True but 275 up front and 315 in rear will work fine with me.
03-15-2013, 08:50 PM | #12 |
I run Michellin PSS, 285/35-20 on all four. Clearance is only an issue on the fronts but with the XAs I have on now it gives me about 1/2" of clearance to the strut. That's with a OE alignment. I'm switching to a track alignment in the next few weeks so waiting on camber plates to achieve that.
03-15-2013, 09:00 PM | #13 |
having FUN now 13.66@101
20 X 9 with a +20 offset in all four corners. Running a 275/40/20 tire size. Love this set-up.
03-16-2013, 12:42 AM | #14 |
275 up front, 315 out back. Nitto INVO.
