Old 03-24-2013, 02:22 PM   #1
Talks Cheap
Talks Cheap's Avatar
Drives: 2010 Camaro SS/RS
Broken aftermarket gear twice
I hade 4.10 gears and LPW cover installed in our 2010 SS 6 speed Camaro, Cam,headers,CAI, 480rwhp at a local Chevy dealership. At less than 200 miles the gear broke off teeth on both ring and pinion gears. The dealer said it was a bad gear. I called Richmond/Motive trying to get them to take a look at the gear and get their opinion, they said I had to call Texas Speed where I purchased it. After several calls and promises that someone would call me and didnt I just gave up and purchased a 4.33 gear directly from Richmond/Motive and had the Chevy dealership install it again. Agreeing to disagree on what happened They warrantied labor but I had to purchase gear and install kit. With about 400 miles on the gear I had a Procharger installed. 4psi and out of fuel pump it made 580rwhp and we left it alone. With a total of 1000 miles on the 4.33s on street tires and no track time the gears went out again while driving normal.
The dealer wants me to install the factor diff (I have the factory one with 3.45s sitting on a shelf) And see if it holds up, which it did for over 7000 miles at 480rwhp on drag radials.
Bad gear or setup? I say bad setup
2010 Camaro SS Texas Speed Cam, OBX Headers, Pypes mufflers, P1-sc Procharger with 4psi boost, 580rwhp, tuned by Justune, ZL1 complete rear.
Talks Cheap is offline   Reply With Quote
Old 03-24-2013, 02:48 PM   #2
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Wow!
I'd personally stay away from anything asssociated with Richmond gears.
I had some bad experiences with Richmond gears back in the day and told myself I'd never run them again.
Old 03-24-2013, 02:50 PM   #3
Talks Cheap
Originally Posted by SGOS252382 View Post
Wow!
What brand gear should I buy?
Old 03-24-2013, 02:55 PM   #4
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
im running richmond 411s and haven't had any issues yet, i would recommend richmond maybe the gears where installed wrong.
casper sc/1ss/rs is offline   Reply With Quote
Old 03-24-2013, 03:10 PM   #5
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Likely bad setups/installs. I've had my Richmond 4.10s for 44K miles with no issues and even made a couple track passes after my cam install (albeit on street tires and conservative launches) . It will be interesting to see how they hold up with my SC added to the mix.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 03-24-2013, 03:10 PM   #6
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Why not Put the 1LE 3.91 gears in it......oh..and take it someplace else to get em installed
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 03-24-2013, 03:42 PM   #7
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
I ran Richmond gears for 2 years, they were fine. They do not hold up well when you hit a certain point. S/C or Stroke is the time to get them out. I would guess you have passed the point of them being reliable. S/C is too much for them to handle. knocking the teeth off is the tell tale sign. Summer teeth. some are here some are there lol
4.10's and supercharged not a good combo.
this is a ls3 ??
if yes drop to 3.73
Mchlgrrsn is offline   Reply With Quote
Old 03-24-2013, 03:56 PM   #8
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Richmond gears are junk! Go with AAM aka Lingenfelter you'll thank me later.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 03-24-2013, 04:04 PM   #9
Talks Cheap
The 4.33s with 580rwhp is/was really fun. It feels/felt old school and also like it should. With 3.45s it would run 65-67mph in 1st gear at 7100 rpm. Youd have to be on the highway or at the track to go through the gears. I mean its my sons car and I have taught him that things can go wrong quick at 100mph and not to do it. I know hell get on it through 1st gear which im ok with. I have gps on the car and it texts me when he goes over 65 mph. I would like to stay with 4.33s but might have to go back to stock 3.45s, sell the procharger and put on a Turbo or Go with a 4l80 and keep the procharger and 4.33/4.10s.
Old 03-24-2013, 04:05 PM   #10
fldrummer
"Black Ace"
fldrummer's Avatar
Originally Posted by Mchlgrrsn View Post
I ran Richmond gears for 2 years, they were fine. They do not hold up well when you hit a certain point. S/C or Stroke is the time to get them out. I would guess you have passed the point of them being reliable. Drag Radials and S/C is too much for them to handle. knocking the teeth off is the tell tale sign. Summer teeth. some are here some are there lol
this is a ls3 ??
if yes drop to 3.73
Mine? Yes. So far, it seems fine. I thought 1st gear would be useless but, so far, that doesn't seem to be the case. When we pulley down, that might change. Also, my tires aren't that sticky, so that may play a roll with how long they hold up as well.
Old 03-24-2013, 04:15 PM   #11
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
actualy i was aking the op ... i see i quoted your specs .. sorry
but if you are waiting to see what will happen when the S/C is entered into the mix, i can answer that. You will shred them within 1k miles providing you shift hard. I know this firsthand. Do yourself a favor drop to 3.70.
Old 03-24-2013, 04:32 PM   #12
Talks Cheap
Driving the car with the 4.33 has been way less hard on the drivetrain. Its like driving in ice with street tires, it just spins the tires. Im sure if it ever hooks it wont b pretty. But we were just driving normal when it happened this last time.
Old 03-24-2013, 04:43 PM   #13
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Plus one....AAM is the company that makes the OEM gears for GM including the 3.91 1LE gears.
I have the 1LE gears on my blown LS3 and traction is minimal
I personally think 4.10's is way too much for the OP and you would be much happier with the 3.91's.
If GM offered 3.73 gears I would have gone that route being blown as it would probably be perfect.
All in all the 3.91's are very good,quiet,easy to install and no failures reported.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 03-24-2013, 04:52 PM   #14
MA2010SS
67 did you end up changing the entire differential to the 1LE or do the gear swap?? I am on the fence about selling my 4.11 JRE differential, my 4th gear tops out at 129mph and I am trapping the 1/4 at 125mph.
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
