03-29-2013, 03:12 PM | #1 |
Help With Hooking Up An Amp
Anyone out there has hooked up an amplifier and subs to their stock BA amp? A bunch of friends and I have been trying for the past two days to get it working properly. They barely hit at all. Anyone have a diagram or something they can show me?
03-30-2013, 09:08 PM | #2 |
2011 Summit White V6 RS
Drives: 2011 Summit White V6 RS MRT 1.0 Join Date: Jun 2012
03-31-2013, 07:37 PM | #3 |
Drives: 13' Sw 2ss Ls3 Join Date: Dec 2012
U can splice a set of cut rca's to the low level speaker outputs on the BA amp look up the sticky diagram works good but cuts off at certain frequencies
03-31-2013, 10:02 PM | #4 |
Drives: 2013 AGM M6 ZL1, 2008 Tahoe LTZ Join Date: Feb 2013
******** x2. Clean install, allows expansion in the future.
2013 ZL1
04-01-2013, 11:41 AM | #5 |
Voice Of The Voiceless
+3 on ********'s FARK harness
04-01-2013, 12:20 PM | #6 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
For simply adding a sub amp to push subs, our x3 harness is all you need. It is item 5g-x3rca on our site. You only need the fark (item 5g-fark) if you are replacing your stock amp. The fark is the cadillac of our harnesses because it contains all of our interface harnesses (including the x3). It would be overkill to get the fark, if you are just going to add subs, but if you plan to upgrade the boston amp down the road (maybe after you do your subs), then it would be a good idea to get the full kit and be done with it.
06-16-2013, 12:58 PM | #7 |
does the ******** eliminate the cutoff of low frequencies or is that controlled by the stereo itself? i cant find them on ebay
