04-01-2013, 09:06 PM | #1 |
Drives: 2013 ZL1 Join Date: Dec 2012
RotoFab
Took a few weeks to post but have to post as yet another happy customer. I was gonna install it myself but wanted to see gains. So I had a before and after dyno. Stock my baby put down 468whp on mustang dyno. After Intake 489whp
04-01-2013, 09:11 PM | #2 |
THE RED ROCKER
Drives: 2013 ZL1 VR Join Date: Feb 2012
Nice work, dig the red on white contrasting colors!
04-01-2013, 09:26 PM | #3 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
Awesome! Installed mine tonight too. Toughest CAI I ever installed, but so worth it. Took me an hour, but could do someone's in probably 40 minutes now. I was crazy paranoid about breaking something.
Now it sounds like my air raid did on my CTS-V.....which was awesome! |
04-01-2013, 09:32 PM | #4 |
Nice!
Sit Back and Enjoy The Ride!!
04-01-2013, 09:41 PM | #5 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
Very nice! I ordered that exact combo last week! It's being delivered tomorrow along with the big gulp and w/w relocation! I can't wait!
Sent from my iPad using Tapatalk HD |
04-01-2013, 10:36 PM | #6 |
04-01-2013, 11:19 PM | #7 |
Thinking about doing this as well......anyone know if it messes with the warranty with GM?
Proud Owner of the baddest Camaro ever built ZL1 |
04-02-2013, 07:55 AM | #8 |
Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
No warranty issues and no tune required. This is why almost everybody is going with this set-up.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
04-02-2013, 08:30 AM | #9 |
Took me a lot longer than any other CAI I've done to install also. The whole system is too tight with too small of a boot. Glad to see proof of a rwhp gain of 21!!
04-02-2013, 08:31 AM | #10 |
Drives: 2010 RS/SS Join Date: Dec 2010
Fantastic, love those roto fabs!
04-02-2013, 09:31 AM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Installed mine on Good friday. One comment I'd like to make is that it would be nice to offer some sort of solution to relocate what appears to be a ground stud that is right up against the end of the air filter.
I didn't even notice it untill it wqas pointed out by someone else afterwards. If that ground stud was relocated, would it then make it possible to remove/replace the air filter without dismantling the intake shroud, etc? or am I overlooking something? |
04-02-2013, 11:22 AM | #12 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
04-02-2013, 11:37 AM | #13 |
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z Join Date: Jul 2012
I had this problem as well on the tube that goes between the Tb and maf sensor housing, TILL i figured out i had that tube in backwards. You might want to check it our if you had the same problem as i did!
04-02-2013, 12:24 PM | #14 | |
Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
Even with the elbow properly installed, the entire intake has closer tolerances in fit as compared to our other Camaro intake systems. The throttle body location forced us to squeeze in all of the components. We refused to sacrifice filter size which means we are close on the jump stud and the air box vertical wall extends to the side of the radiator. Performance/accurate MAF readings dictated the shape as well as the overall length of the MAF housing. Our intakes use a rigid mounting system to the air box which provides a tight seal to prevent air from entering the filter. With this mounting, we must incorporate a flex or hump hose to absorb motor rock. From there we make the radius on the inlet elbow as gentle as possible while still maintaining adequate clamping surface on either end of the elbow. On the throttle body side, we use a step hose which also absorbs some engine movement while providing positive alignment to the throttle body. It all goes together and functions great, but with absolutely no room to spare! |
