04-06-2013, 10:46 AM | #1 |
Problems with 265/35/22 on Fronts??
These are my Modulare 3 piece M22 Gloss Black w/Chrome Lip. Pirelli Scorpion Zero's 265/35/22 Fronts & 295/30/22 Rears.
Has anyone experienced problems with mounting 265/35/22 on the fronts and having the inner tire rub on the shock tower spring plate? The manufacturer claims a +35mm offset is correct, I don't think so. |
04-06-2013, 05:04 PM | #2 |
Drives: '14 SIM 2LT/RS Vert Join Date: Aug 2010
Those are the same size tires I'm running. I added a 5mm (I think) spacer on the front because the tire was touching, or very close to it.
My front wheels are 22X9, +35mm offset.
04-07-2013, 12:06 PM | #3 |
Thanks for the information. I was also looking at adding a 5 or 10mm spacer according to some of the feedback I've been getting.
04-07-2013, 03:41 PM | #4 |
Drives: Dark Knight Join Date: Sep 2012
+35 offset is correct, the tires are the problemo!
04-07-2013, 11:55 PM | #5 |
Gixxer 1000
Drives: 2012 Camaro 1SS M6 Join Date: Mar 2012
Ive got 22X9 Asanti with a 32mm offset, lowerd with that same size tire and no rubbing at all.
