04-09-2013, 08:45 AM | #1 |
Drives: 2010 camaro 2ss/rs Join Date: Jun 2011
Kooks headers/ catback Noise Issue
I purchased a set of kooks 1 7/8" headers with a street sleeper catback and high flow cats. Finally got to get them installed. I have noticed that they make a tapping sound. It only does it when I make turns or drive on bumpy roads, then it really gets annoying. I love the sound of the exhaust with headers but any way to fix this issue? Thanks in advance !
04-09-2013, 09:10 AM | #2 |
You'll have to check your clearance around the entire system. Try to pinpoint where the sound is coming from to the best of your ability. Then get your car back up in the air and try to track down the sound.....try to wiggle the system to see if you can find where it might be making contact. Best thing to do is loosen all the clamps on the system and try to get enough clearance around anything that might need it. A popular spot is the driveshaft tunnel brace, especially if you went with the 3" system. You can add some washers to it for the extra clearance you need.
04-09-2013, 10:13 AM | #3 | |
Logic is dead
http://www.camaro5.com/forums/showthread.php?t=217634 I have had issues with Kooks headers impacting my steering column. This is most noticeable when making turns. See if you see any grinding affects on your steering column near the driver header.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ - Vortech V3 Supercharger - Kooks Stepped Headers, Magnaflow 16580 - Suspension by Pfadt, Hotchkis. 2007 Trailblazer SS- Sold 2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold 1994 Camaro Z28 - Sold |
04-09-2013, 10:45 AM | #4 |
Drives: 2015 Challenger SRT Join Date: May 2011
I just have a catback and I am experiencing tapping noises when going over bumps too. I just don't have any noises while turning. I'm suspecting my exhaust is hitting the tunnel brace when I go over bumps. I plan on getting under my car and loosening all the clamps and aligning the exhaust some more to see if I can get better clearance and to see if that resolves the tapping issue.
04-10-2013, 09:01 AM | #5 |
Thanks guys im going to try & pinpoint it out it sounds like its coming from up front though. Ill definetly be taking it back to the shop & get it fixed.
04-10-2013, 02:13 PM | #6 |
I had the same problem when i got my borla atak catback. check your tunnel brace clearance, chances are your new pipes are hitting it.
04-10-2013, 02:16 PM | #7 |
This was my guess as well til you said front.
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
04-10-2013, 05:27 PM | #8 |
Drives: 2012 SS LS3 | Silver Frost Metallic Join Date: Apr 2011
Exactly. I had this and it was driving me nuts. I bought the Elite Engineering Tunnel Brace and it took care of it, looks fine and was manufactured nicely.
__________________________________________
Ironman John |
04-10-2013, 08:00 PM | #9 |
I jacked my car up last night and re-adjusted my catback. It has plenty of clearance now on the tunnel brace and now there is no more rattling when I drive around, including if I go over bumps.
04-11-2013, 01:20 PM | #10 | |
It might sag again and make contact over time. Just an FYI!
Ironman John |
04-11-2013, 01:29 PM | #11 | |
Best regards, Tyler 888-308-6007 |
04-11-2013, 03:46 PM | #12 |
Thanks for the recommendation Tyler! I have some driving to do over the weekend, so that will help get in my 50-100 miles in so I can check and re-tighten everything.
04-11-2013, 04:17 PM | #13 | |
