04-18-2013, 07:20 PM | #1 |
Drives: 2022 Camaro ZL1 Convertible A10 Join Date: Aug 2012
ZL1 - 1500 miles at last
I finally reached 1500 miles on 4/17/2013 (took 4 months)
Took it to dealer today for: 1. oil and oil filter change (Castrol Edge with Titanium) 2. 1500 mile inspection 3. installed skid plate/scrape protector under front spoiler 4. had the little donut spare tire mounted on rim I feel a whole lot better going on road trips now. FYI the donut spare tire kit is GM part number 19257799 includes: 1. scissor jack 2. lug wrench/jack handle 3. donut spare tire (must be mounted on rim) 4. rim http://www.newgmparts.com/parts/inde...&siteid=213815 |
04-18-2013, 07:30 PM | #2 |
5. changed rear diff fluid too
04-18-2013, 07:45 PM | #3 | |
Drives: ZL1 Convertible Join Date: Aug 2012
http://www.camaro5.com/forums/showthread.php?t=225661 I don't think it will work with a ZL1 |
04-18-2013, 08:00 PM | #4 |
Drives: '12 Camaro ZL1, '16 Silverado Z71 Join Date: Mar 2012
5. Press right foot to floor and HANG ON!!!
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust |
04-19-2013, 02:38 PM | #5 | |
my ZL1. GM part #19257799 The 18 inch wheel will not clear the front Brembo brake. It would destroy the brake caliper if it was torqued all the way down. I am returning the spare tire kit for a refund. apparently GM does not make a ZL1 spare tire donut. |
04-19-2013, 03:19 PM | #6 |
Drives: '11 VR 2LT HHr Join Date: May 2011
Will the donut spare fit over the rear brakes.
If it does fit and you have a flat on the front. You may end up putting a tire from the rear on the front and then put the spare on the back. Kinda dumb not having a suitable/useable spare that can be used at all four corners ~
2011 Hhr
Formerly known as Silver85IrocZ !! |
04-19-2013, 03:53 PM | #7 | |
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno. |
04-19-2013, 04:42 PM | #8 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
DID YOU GET THE FRONT SPRING SPACERS THAT ARE NEEDED TO FLAT TOW THE ZL1?
MANY TIMES AT THE INITIAL INSPECTION THEY ARE THROWN AWAY. THEY NEED TO BE INSTALLED BEFORE YOU HAVE A TOW TRUCK LOAD IT ONTO A FLAT BED. MINE WERE YELLOW AND THE DEALER HAD TO ORDER ME A SET AFTER THE TECH THREW THEM AWAY AT THE PRE DELIVERY INSPECTION
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
04-19-2013, 05:40 PM | #9 | |
I was furious that GM did not think to design a spare tire donut specifically for the ZL1 20 inch wheels and large Brembo brakes. I will have to use that inflation/sealant device that came with car and pray that I don't have a flat when taking road trips. |
04-19-2013, 05:51 PM | #10 |
You might want to look here, I don't think there is any difference in the SS and ZL1 brakes, the adapter is what makes it all work. I would be a little skeptical about using the spare on the rear ( limited slip) rearend,, and I don't know if the 10" wide rear rims would work on the front if needed. Please let us know what you find out. I would feel better having a real spare, but even a doughnut would get you home.
http://www.performancespare.com/Available_Kits.html
2011 Camaro 2SS
1969 Camaro BB 472 NOS 1997 Camaro Z28 Last edited by Learjetguru; 04-19-2013 at 05:58 PM. Reason: update |
04-19-2013, 06:30 PM | #11 |
Drives: '21 ZLE A10 Join Date: May 2012
looks like $349 from the web site above would work. http://shop.performancespare.com/CAD...-KIT-CTS-V.htm
04-19-2013, 06:41 PM | #12 | |
I've heard the rears do NOT fit on the front. they are too wide and rub (significantly). |
04-19-2013, 08:21 PM | #13 |
Yea didnt think of the size of the
rears. And Yes G.M should have thought of a spare for any thing other than the LS/LT's ! edit: added cuz i earned
2011 Hhr
Formerly known as Silver85IrocZ !! Last edited by DwRed1LTV6; 04-20-2013 at 08:25 AM. |
Thread Tools | |
