![]() Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
Starting Problem
The problem I'm having is starting after just a few miles of driving. Cold starts, no problem. Hot starts after 10 or more miles of driving, no problem. Yesterday I started the car (2SS/RS, Manual trans) for the first time that day and drove just a few miles to the gas station for a drink. I came out and cranked it up and the car sputters and spits for a few seconds then returns to a normal idle. It's done this a few times the past month since I added my CAI cold air intake. The only other mod I have is a muffler delete. Any ideas?.
U.S. Army Retired |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
No gas ?
![]() Drives: 2011 LT Black Join Date: Nov 2011
Bad gas maybe.
Prolly that time again to cleaner the injectors.
Plenty of gas in the tank and I only run 93 octane. Any recommendation on injector cleaner? I've heard good stuff about BG injector cleaning service.
U.S. Army Retired |
#6 |
![]() ![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
If the CIA has an oiled filter, I'd check the MAF sensor. If the MAF gets coated in oil, the car runs/starts like crap.
#7 |
Thank you for the info sir! I'm assuming there is no way to clean the MAF due to how delicate the wire is on it?
U.S. Army Retired |
#8 |
Maybe a little carb cleaner on the MAF? Then let it sit and dry thoroughly. Might help.
Life is short, drive it like you stole it! ![]() |
#9 |
MAF is cleanable, they sale a cleaner specifically for MAF sensors at auto Stores,
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Do you let the injectors prime prior to cranking it?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#11 |
I'll make sure I turn the key on and let it sit for a few seconds befor cranking from now on. I'll also get a can of MAF sensor cleaner and give it a squirt. Thanks for the replies everyone!
U.S. Army Retired |
#12 |
![]() Drives: 2011 Race Red GT500 w/ SVT Perf Pkg Join Date: Mar 2009
If after cleaning the MAF sensor, and there is no change, I would try reinstalling the original intake, and see if the sputtering goes away. That might be the fastest way to help diagnose the trouble.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
What intake did you put on, K&N is known for issues.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Stupid question , but did you re-install the MAF with the arrow pointing in the right direction?
