04-27-2013, 02:12 AM | #1 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
A couple more dumb questions
Ok! I haven't messed with car audio in years!
I'm almost done installing my sub and mono amp. I'm running a 4 gauge power wire from the POS into a fuse block and going to probably run 8 gauge from the fuse to the amp. How in the hell do I find a ring terminal large enough for 8AWG but small enough to fit onto the amps screw down clamp? Also: Do I ground the amp to a chassis ground? Or NEG on the battery? Third: If I have a ******** box for the drivers side and a ******** box on the passenger side, how can I wire them both to a mono amp? (Alpine VR500)
L99 With a Maggie
04-27-2013, 07:13 AM | #2 |
Ring Terminal? - Stereo Shop?
Usually you ground to the chassis. 2 subs to a mono amp? I think you just hook both cables up to the same output if there is only 1 output. |
04-27-2013, 08:21 AM | #3 | |
Drives: 2010 Camaro SS Join Date: Apr 2013
04-27-2013, 08:52 AM | #4 |
Drives: 2011 Synergy Green Camaro LT Join Date: Jul 2011
You can run 2 pairs of speaker wires, 1 to each sub from the amp, no problem there.
04-27-2013, 10:32 AM | #5 |
Drives: 2010 Camaro 1SS IOM M6 Join Date: May 2012
I was also wondering if you should ground to the negative terminal of the battery or the chassis. Is there a factory ground somewhere in the trunk we can bolt to? Also, is it better to run multiple grounds to the same point? What about using a distribution block for grounds?
04-27-2013, 11:08 AM | #6 | |
Drives: 2017 2SS Hyper Blue Join Date: Apr 2009
Mods-Corsa Extreme Axleback
04-27-2013, 09:32 PM | #7 |
We have BOOM!
I only installed one of the 10" subs and it hits nice and tight. I am impressed and loving the sound. Thanks guys
L99 With a Maggie
04-27-2013, 10:30 PM | #8 |
Drives: 2013 2SS 1LE Join Date: Mar 2013
if you are wiring your subs in parallel, just make sure your amp can handle the lower impedance... don't want to fry your amp cause it can't handle it...
wiring parallel is what the folks above recommended, which is the most common, but it halves the impedance the amp sees. so, if you have 2 dual 4 ohm subs in parallel, the amp will see a 1 ohm load... some amps can't handle this. if you are just running 2 single 4 ohm subs, the amp sees 2 ohms, and a majority (if they are sub amps) should be able to run this no problem. just want to be sure you are taking care of your equipment. |
