Old 05-12-2013, 07:45 PM   #1
Tylers Camaro
Tylers Camaro's Avatar
Drives: Black 2011 Camaro Ls
Question Would this be all I need to do Angel Eye Halo Headlights HID conversion?
I've seen the DIY thread on the HID conversion but I wanted to know if this kit had everything I needed to do the conversion without ordering the conversion kit from a separate source.
http://www.ebay.com/itm/6000K-HID-10...929b32&vxp=mtr
In the description below it says "Complete set includes Left and Right Sides Headlights and 6000K HID Conversion Kit with ASIC Ballast and ( H9 Hi/Low for Halogen, if you want to apply HID, you will need to get H11 HID kit for Low Beam application only, Leave High Beam Blank ) HID light bulbs"
I don't understand why it says if you want to apply HID you will need.... I thought it says it comes with the conversion kit needed. Does that mean I need to buy additional bulbs or wiring harnesses to make the HIDs work?
Tylers Camaro is offline   Reply With Quote
