Old 05-19-2013, 02:42 PM   #1
TidewaterShark
Kevin
TidewaterShark's Avatar
Drives: 2010 2LT IBM
HU gone Bad?
I think I am having problems with my Head Unit. Or my JLAudio XD700/5 does not like my HU.... But not 100% sure.
Has anyone had there HU go bad. If so, How did you know? What was going on with it?
TidewaterShark is offline   Reply With Quote
Old 05-19-2013, 06:51 PM   #2
TidewaterShark
Kevin
I have the BA system. Replaced all speakers. Center speaker not hooked up. This is my 3rd amp(xd700/5) and still have problems. First amp, after it would warm up. It would do all crazy shit. 2nd amp, was bad ( no sound front left. Sent it right back. Got a new one. 3rd amp and still having problems. when the volume is low 8 to 10. sometime I lose the doors climes. I turn the volume up slowly door chimes come back on. But right front speaker goes crazy. Like all bass and mids go away and I get nothing but screaming highs. If I crank up the volume knob up Fast and back and forth, Right front speaker goes back to normal sound.
Things that I have check.
swapped left and right front speaker to see if maybe speaker was bad. Not bad.
swapped line inputs, front right to left and left to right same to the rear speakers.
still have the same problem with right front speaker.
Sure could use some help solving problem..
Thanks
Old 05-20-2013, 04:09 PM   #3
TidewaterShark
Kevin
bump.
Old 05-20-2013, 04:37 PM   #4
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
So you have a jl xd 7005 that you changed out three times and you are still have problems is it just the door chime I am think that when you hooked the first amp up you might have blown a speaker or your high low might be bad if you have a Multi meter ck the speaker Resistance or ohm if one is different then the other there is your problem. Also when you put in the aftermarket amp did you change the speakers????
lfree11012 is offline   Reply With Quote
Old 05-22-2013, 08:19 PM   #5
TidewaterShark
Kevin
I already swapped the front speakers, left to right. right to left.. problem still in right front.. I have all new speakers..
Old 05-22-2013, 08:24 PM   #6
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
Ok are you still using the oem radio if so what adapter are you using if you are using aftermarket radio what harness are you using
Old 05-22-2013, 08:51 PM   #7
TidewaterShark
Kevin
oem head unit. using ********er 5G-FARK Harness
Old 05-23-2013, 06:27 AM   #8
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
Ok how high do you have the front gain set on the amp. Also I am assuming that you took the oem amp out and are also using the feanks amp mount and wireing harness try Turing the the front amp gain down to less then hafe and turn radio volum up and see if that helps also franks has a troubleshooting o. There page I have seems this problem a few times with gm oem gm radios after every thing was said and done just end replacing oem radio with an aftermarket one
Old 05-23-2013, 05:08 PM   #9
TidewaterShark
Kevin
yes, oem amp was taken out. The gain is turned all the way down. I guess your talking about the input sensitivity? My amp is mounted in the same place as the old amp and using the oem wiring.
Old 05-23-2013, 05:44 PM   #10
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
I would call that a bad head unit New speakers three amp swap later and a whole lot of time retracing your install only point to one thing
Old 05-23-2013, 05:56 PM   #11
TidewaterShark
Kevin
Thank you very much for your input. Now to find a HU for cheap. I have seen a few on here going for a $100. but really don't want to pay that much.
Old 05-23-2013, 06:04 PM   #12
TidewaterShark
Kevin
one more thing.. do I need both parts of the radio?
Old 05-23-2013, 11:01 PM   #13
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
I suppose you could get away with just replacing the brain unit, but I haven't seen anyone selling it separate. Buying a brand new one from GM Parts Direct is $211 (+ shipping I'm sure) so $100 is not a bad deal if you're getting both parts. I'd sell you mine (Brain, Control Panel, and PDIM) for $115 shipped if you want. Otherwise, Hampton is a mere 3-1/2 hours from Raleigh
Good luck man.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-24-2013, 09:42 AM   #14
TidewaterShark
Kevin
I take it that the brain unit is the silver box? - just bought the latest PDIM.
