05-31-2013, 11:37 AM | #1 |
G200 Pilot
Drives: 2010 Camaro SS/RS purchased 5/2010 Join Date: Dec 2010
DRAG CAR/STREET LEGAL/TRAILER FOR SALE
FASTEST STREET LEGAL 5TH GEN CAMARO (2010) IN FLORIDA AND 4TH FASTEST IN WORLD (CATEGORY 7) 9.50 AT 148 MPH. 965RWHP. ENGINE: JANNETY BUILT 416 STOKER COG DRIVE UPGRADE.. 75/344.000 X 6.125 2.1004340 EAGLE CRANKSHAFT, H BEAN ROD, 6.125X2.100 WISWCO COATED 4.070 15 CC IS3 1.110 DISH PISTONS, ROD BEARING SBC 2.100 COATED LS MAIN BEARING COATED KIT/DIS WASH, BLOCK HONE CYLINDERS WITH TORQUE PLATE .005, LINE HONE MAINS AND INSTALL ARP MAIN STUDS, ASSEMBLY BALANCED HAND BLEND VALVE JOB INTO PORTS AND FLOW TEST RESURFACED PAIR OF HEADS TO 70 CC, TOUCH UP VALVE JOB, C&C PORT CYLINDER HEADS, GEN 3 TIMING CHAIN (3/8 X7/32), GEN 3 LS SB 2004 & LATER WITH ALL SAME LENGTH STUDS, EXHAUST 2" OFF ROAD HEADER KIT, 6.2 3" STAINLESS COMPETITION CAT BACK, 4" TIPS JRE MODIFIED TRUE 3", VORTEC YSI RACE SUPERCHARGER, JRE SUSPENSION 90/10 FRONTS 50/50 REARS, REMOTE BATTERY DISCONNECT & HIGH AMP ALTERNATOR DISCONNECT, FUEL SYSTEM: 10 AN BYPASS PRESSURE REGULATOR STEALTH ELIMINATOR FUEL SYSTEM WITH A 1000 PUMP SPEED CONTROLLER, FUEL RAILS INJECTOR DYNAMICS 1025 CC INJECTORS, WHEELS AND TIRES: BOGART 16 " FRONT AND REAR WHEELS, 28X14.5X16 QUICK TIME HOOSIER PRO D.O.T. TIRES/ TUBES, 315 MICKEY THOMPSON DRAG RADIALS (NEW) 625, DIVE TRAIN: 4L80 RPM TRANSMISSION, TRANS BRAKE, 2 STEP, DDS DRIVE SHAFT, PFADT SOLID CRADLE BUSHINGS, COOLING: PT 2000 AIR TO WATER INTERCOOLER, INVERTED INLET AND OUTLETS, 10 GALLON CHILLER TANK WITH LARGE INLET CAP, MEZIERE 55 GPM PUMP, PROCHARGER (RACE) BLOW OFF VALVE, PARACHUTE AND HARDWARE INSTALLED, 10 POINT ROLL NHRA CERTIFIED ROLL CAGE, TRAILER FULLY LIGHTED, 5000 LB WINCH, CABINETS AND ALSO NEW TIRES, (4) EMAIL ME AT CONNIEINPALACE@AOL.COM IF INTERESTED
06-03-2013, 08:13 AM | #2 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
BEAUTIFUL CAR
Someone is going to get a hell of a deal,on this car. I really enjoyed watching it run at the track.
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
06-04-2013, 06:44 AM | #3 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
I see Howard giving you a pointer or two . If they did anything to the build, its quality!
06-05-2013, 01:16 PM | #4 |
Drives: 10 Procharged SS Join Date: Oct 2009
Bump for one hell of great deal!!!
Very nice car man |
