06-18-2013, 10:38 AM | #1 |
Drives: 2021 Camaro ZL1 A10 Join Date: May 2013
Question about the ZL1 drivetrain?
First I realize that this is probably an obvious question, and I also could probably figure it out. However, I'm sure a lot fo you could answer this question off the top of your head. Please explain.
Does the ZL1 have the same drivetrain, clutch, trans, rear end, as a 1LE. This is an offshhot from another thread in which the issue of "just" putting a supercharger on an 1LE and you wil have ZL1 power from a SS. |
06-18-2013, 11:52 AM | #2 | |
Drives: 2012 ZL1 Join Date: Dec 2011
2012 CTF ZL1-stock
2012 ZL1 (sold) JRE 75rwhp kit catless ported lsa TB 11.04 @ 128.35 on hoosier drs and skinnies @ PRP with 1100DA |
06-18-2013, 11:57 AM | #3 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
The tremec6060 in the ZL1 is an MG9 which can handle 30% more torque. The rear gear in the ZL1 is 3.73, 3.91 in 1LE. The LSA has hypereutectic pistons, piston oil squirters and forged rods. The clutch in the ZL1 is beefier as well.
06-18-2013, 04:43 PM | #4 |
Thanks for the details guys!
Like I said earlier, it only makes sense that GM would beef up the drivetrain with the increased power. Thanks for the details. |
