06-20-2013, 01:33 PM | #1 |
Drives: 2017 red hot zl1 Join Date: May 2012
will this size and off set work
I have searched and read etc but can not find anything out. So sorry if this is a redundant question for this section.
I do not car if they stick out a little bit but I do not want them to rub when the wheel is turned etc. or will I need spacers. I am really not a fan of spacers though. 19x10 5x4.75 +40 or +56 19x12 5x4.75 +56
2017 ZL1 built by GPI. Way to many mods to list 855rwhp/720rwtq
06-20-2013, 06:23 PM | #2 |
thinking of running a 275 or 285 tire up front and a 285 or 295 out back
06-20-2013, 07:44 PM | #3 |
Quit being a pu$$y
If you want those wheels you will need spacers on front and rear. Fronts will need at least a 10mm spacer (which will require longer studs) but they will fit right at the edge of the fender. The rear will need a 1" adapter and they will stick out of the fender about an inch. a 1/4" to 1/2" poke out is a little noticeable, but a 1" poke out will look ridiculous.
06-20-2013, 07:59 PM | #4 |
so if I want to run a 19x10 40mm i will need a 10mm spacer all the way around.
will spacers hold 600+rwhp ? what will not clear with the 40mm off set and what off set would fit right at a 19x10 all the way around
06-21-2013, 01:30 AM | #5 | |
Quit being a pu$$y
