08-08-2014, 11:48 PM | #141 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
I just put the cover back on. I wouldn't go back to the llt manifold for anything.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
08-08-2014, 11:53 PM | #142 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
So this thing will basically act like the spacers many of us are using and should increase runner length, and then allow us to use the LFX manifold...but if I'm doing that, then the best choice is to go with Jason's "ported" LFX manifold which flows better. Not sure if you guys check out the LFX section, but he's recently been doing testing on his LFX spacer and the ported manifold, and had great results. See the 3rd chart on this post here: http://www.camaro5.com/forums/showpo...&postcount=332 The spacer gave nice gains down low, while the intake gave nice gains up top...in all 15 hp and 15 tq gained. Very nice! I don't think you'd want to run this spacer by itself on the LLT, as it seems this will still transfer heat into the LLT's aluminum manifold which is part of the big benefit of using the other current spacers on the market. Jason...do you mind posting what this cost, and if you know the thickness that would be great info as well.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
08-08-2014, 11:59 PM | #143 | ||
The only downside is, a painted cover will never show as well as an visible manifold that is custom done like mine unless I put more work into it. Maybe I'll cut some ports out and add some mesh...that could work.
08-09-2014, 06:17 PM | #144 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
My cost on the part from the dealer was $280, but I've seen it as low as $265 new shipped ground to your door. GM List price is $367.98. I can't remember how much my dealer charges me for the LFX upper intake manifold, but it's quite a bit cheaper than the list price of $354.99. A quick search online shows me that the cheapest place to get both the LFX intake, and the Traverse LLT lower intake is Summit Racing, for $506.94 w/ free shipping. Aside from that, you will still need: -bolts -GM oring gaskets that go into the bottom of the composite intake -the PCV line that runs from the rear of the pass side valve cover to the center/front area of the intake (the one you cut for the catch can install) -The LLT evap solenoid hardline might work, but you will have to contort it out of it's original shape. The LFX evap solenoid hardline is recommended and is a straight swap. -the LFX TB oring gasket (but you can use your LLT TB, and pretty sure the TB bolts also) -The LFX EVAP solenoid w/ bolt (pretty sure it comes with the bolt if you but it new) -You will either need to buy the LFX MAP sensor (& bolt) just to plug the hole in the intake, or just plug the hole with a pipe plug and some sealant. If you use something non destructive (like the map sensor) it will make the manifold easier to sell (to the LFX crowd) if you decide to . The LFX intake composite intake, w/ aluminum lower part is about 12lbs lighter than the LLT intake manifold. I think that should answer most questions about what would be needed? Unfortunately I don't have part numbers and prices available for everything as I'd need to go to the dealer and pick stuff out on the diagrams on their computer as it's not all listed for purchase on most internet GM parts sites. Vararam intake may not be a straight bolt on, a different silicone coupler MAY be required. Stock intake, and all other aftermarket cold air intakes should work without any issues. Am I forgetting anything? Once this part shows up and I 100% confirm it will bolt on and work, I will have a complete setup with everything mentioned above that you would need to try on a car... |
08-13-2014, 07:18 PM | #145 |
Pay dirt...
08-13-2014, 07:46 PM | #146 |
Cool.
08-13-2014, 08:20 PM | #147 |
Drives: 2011 CGM 2LT/RS Join Date: May 2011
Nice! What size bolts will you be using?
08-13-2014, 09:09 PM | #148 |
Haven't checked yet, rough guess, five 140mm long and one 130mm will most likely be perfect.
08-14-2014, 12:09 AM | #149 |
Drives: ZTS pearl in autoflex Join Date: Sep 2013
Let me know if any butt dyno power gains!!
Full MBRP 3in exhaust, Vitesse TC, BBK LT, black iceolator, VMAX TB, vararam, LG coils, zl1 reps, zl1 front bumper, zl1 grille, zl1 rockers, CF Copo hood, CF trunk, gm blade wing, HAVOC diffuser, APR splitter, dipped SS calipers
08-14-2014, 09:21 AM | #150 | |
Ahh yes...my comment above about it not being a good idea to run this as a spacer on the LLT wasn't thought out. lol. Your right...its not even possible. I don't know what I was thinking.
So even with the rx spacer and the LFX intake setup, these lengths would probably worth. If the spacer is longer, you might want to bump up the lengths another 10mm
08-14-2014, 09:38 AM | #151 | |
It may be best off if you use the VMAX isolator under the bottom, and maybe if I made a 3/8-1/2" spacer for between the upper and lower intake. Using my 3/4" + the VMAX 3/8 (1 1/8") total may be too much of a runner length increase and not be that great for top end. Or just can the VMAX all together and use mine. It would be to be tested multiple ways and a crap load of dyno runs would have to be made to see anything conclusive. I wouldn't over analyze the spacer thing until just the intake is tested by itself. The nice thing is if I end up being able to successfully run the LLT heads on an LFX, I can still use this to run the LFX ported intake. Perhaps the best of both worlds. |
08-14-2014, 10:32 PM | #152 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
08-15-2014, 12:04 PM | #153 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
08-16-2014, 04:47 PM | #154 |
Drives: Corvette C6 500 HP Join Date: Dec 2011
Plastic intake Manifold
Any up dates on LFX Manifold fitting to LLT Heads yet.......Thanks.
2011 Camaro RS Convertible M6
