07-19-2013, 11:59 AM | #1 |
Drives: 1LE Join Date: Jun 2013
Change rear diff before track day on Monday
Thus will be tge third time to the track. It has 2800 miles. Should I use stock gear oil or something else. Thanks
Sent from my SAMSUNG-SGH-I337 using Tapatalk HD |
07-19-2013, 12:07 PM | #2 |
Drives: cars Join Date: May 2011
Mobil 1 or Royal Purple with a bit of limited slip additive. Track sessions are hard on fluid and generate a ton of heat, its better to have a synthetic and change it regularly due to the abuse.
07-19-2013, 05:28 PM | #3 |
Drives: 2013 Camaro SS 1LE Join Date: Jul 2013
does the 1LE have a diff cooler like the ZL1??
07-19-2013, 05:38 PM | #4 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
07-19-2013, 05:54 PM | #5 |
Drives: 2022 SS 1LE Join Date: Jul 2013
Yep, I would change it prior to hitting the track.
I was told by my dealer that the stock diff fluid is synthetic. I just had them service it with synthetic, going to the track this weekend.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
07-19-2013, 05:56 PM | #6 |
Drives: 2012 Camaro 2SS Join Date: Feb 2012
A drive to the grocery store is creates more heat than a 14 second track run.
07-19-2013, 06:18 PM | #7 |
07-19-2013, 11:03 PM | #8 |
It will be road course. Thanks for the replys. I will stop by dealer tomorrow. And post some pics.
07-19-2013, 11:07 PM | #9 |
Where would you get this? Brand names?
"Democracy Dies in Darkness" |
07-19-2013, 11:08 PM | #10 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
You need to change after 24 hours of track time. See the manual.
07-20-2013, 02:35 AM | #11 |
