07-22-2013, 05:05 AM | #1 |
Drives: Black Camaro 2SS/RS 1LE Join Date: Jun 2011
How to install MSDS fuel pump voltage booster?
Hey everyone . It's only 2 days away....the start of my Magnuson supercharger install. I have everything I need (I hope ). The only thing I don't have a clue about is how to install the MSDS fuel pump voltage booster. I looked on youtube...nothing. I looked here and nothing. The paper that came with it shows how to hook it up (schematics) but nothing else. My mechanic friend is actually doing the install and I'm the helper, but I'm not sure if he knows about this or not. He's a certified Hyundai mechanic so no vehicles over 200HP . The information I did find about this is....it is easy to install. Just no "how to"
Thanks |
07-22-2013, 06:43 AM | #2 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
You can download instructions with pictures off of east coast superchargings website. Not sure what brand of bap they use but it might be of some help
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
07-22-2013, 08:26 AM | #3 |
Just splice the Red/white wire to the FMCM. Red wire on connector side, Orange on side going to trunk. Hook red and black to battery and run vacuum line. Then hook to computer and set the voltage.
07-22-2013, 02:24 PM | #4 |
Drives: 2010 2SS Join Date: Jan 2013
yup, it very easy
07-22-2013, 02:45 PM | #5 |
This Looks Very familiar
www.jannettyracing.com
07-22-2013, 06:21 PM | #6 |
07-22-2013, 07:17 PM | #7 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
lol.
07-22-2013, 08:18 PM | #8 |
I hope my mechanic friend that's doing the install knows how to decipher this or I'll just install my headers and call it a day!
I need to take off the rear passenger side panel (has the arm rest for back seat passenger), correct? Where does the fuel pump voltage booster bolt to? Underneath the car? Wires to the trunk to connect to the battery and wires spliced with wires that run behind the now removed panel? Where does the plug on the fuel pump voltage booster plug into? |
07-22-2013, 08:44 PM | #9 |
Yes remove the passenger side panel and run the power and ground to the battery.
Here's 1 location to install it. http://www.camaro5.com/forums/showpo...07&postcount=2 How I installed mine. http://www.camaro5.com/forums/showpo...55&postcount=2 |
07-22-2013, 09:07 PM | #10 |
I like the idea of putting the FPVB in the trunk and running the wires where they need to go. But why do I have to pull off the passenger side panel?
07-22-2013, 09:44 PM | #11 |
07-22-2013, 09:57 PM | #12 |
FPCM = fuel pump computer module?
07-23-2013, 11:31 AM | #13 |
Drives: Fire Engine Join Date: Oct 2008
Big C, this is the schematic I used and it was easy. Mine was mounted in the trunk and I tapped into the fuse block just behind the passenger side rear tire in the trunk, not the passenger compartment.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile 11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires. Sold |
07-23-2013, 02:00 PM | #14 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
Make sure the MSD is properly programmed. Too low and it won't do much. Too high and it will throw the CEL.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
