08-05-2013, 09:35 AM | #1 |
Drives: 2013 ZL1 CPE Join Date: May 2013
1/4 mile
Best time so far has been 12.446 on M/T drag radials I have 6spd manual with SLP stage 3 package does any one have suggestion to improve 1/4 mile time
08-05-2013, 09:51 AM | #2 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Posted from Camaro5.com App for Android
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
08-05-2013, 09:52 AM | #3 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
If you post a time slip it would really help. What's your 60' time? What's your trap speed? I'm guessing your 60' time is pretty high and that your are spinning on launch. What RPMs are you leaving at? Lots of variables here to give advice without more info.
For reference, at Camaro5Fest this weekend, I put down a 12.1 on stock tires (fully aired), on a 1.884 60' time at 115MPH. I was happy with it considering my DR's were sitting back home in the garage. |
08-05-2013, 09:56 AM | #4 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
practice !
08-05-2013, 10:01 AM | #5 | |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
And what Mode?
08-05-2013, 10:02 AM | #6 |
2.088 at 60'
08-05-2013, 10:40 AM | #7 | |
COTW 12/3/12
I also backed into the water box every time, something I don't usually do at home, so I am going to have to try that too. My goal by the end of the season is to run a 11.5 ET. |
08-05-2013, 11:30 AM | #8 |
Drives: 2000 Camaro SS 2013 ZL1 Camaro Join Date: Jul 2012
Try Launch control, are you getting the car too hot waiting to make your run? Your running at least 91 octane i am assuming. R/T ? I can get those times with just a rotofab intake and stock tires in florida heat
08-05-2013, 11:39 AM | #9 |
Was using PTM 5 but wasn't using my launch control I did try it feels like theres a dead spot at take off not sure if its in the tune they did at SLP. I will try launch control Friday during test & tune at commerce ga.
08-05-2013, 02:20 PM | #10 |
Drives: '21 ZLE A10 Join Date: May 2012
2.08 is not good. Either you are too tenative or the car is bogging slightly. Please post the entire slip to see the splits. I would turn all of the traction control devices off and run like that with drag radials. The M6 cars I have seen posted here never run well in the PTM modes or using launch control with drag radials.
08-05-2013, 04:26 PM | #11 |
Drives: 2012 ZL1 Join Date: Dec 2011
turn off all traction controls, heat up the dr's well, run about 18psi in them, find the launch rpm that doesn't bog and doesn't spin. probably around 4000-4500 slipping the clutch slightly as you launch, don't just dump the clutch. What mph are you getting?
2012 CTF ZL1-stock
2012 ZL1 (sold) JRE 75rwhp kit catless ported lsa TB 11.04 @ 128.35 on hoosier drs and skinnies @ PRP with 1100DA |
08-06-2013, 06:17 AM | #12 |
been getting 115 to 116
08-06-2013, 06:47 AM | #13 |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
Trade M6 for an A6? (Jk)
