08-27-2013, 11:20 PM | #1 | |
COTW [4/23/12]
Drives: Camaro Of The Week. Join Date: Aug 2011
Finally Acs T4 ports just came in, but......
but the DRL LED lights wont fit it. if you click to link below it will send you to rideskinz 1st bumper group buy, and i bought exactly the same light setup for the light. if you see the picture below there's a bit of a gap of the ports (top bottom and middle to slide in the slight in the lights), its just like couple millimeters away. should i tell the body shop to cut the ports to fit the lights? or i buy another light setup (but where should i buy? somehow this ports is kinda small than i expected.)?
http://www.camaro5.com/forums/showthread.php?t=248694 to the drl setup http://store.ijdmtoy.com/Euro-Brabus..._ddl_sku79.htm
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune | My Build Thread |
08-27-2013, 11:27 PM | #2 |
HTCC Member
Have the body shop sand down the ports a bit .
08-28-2013, 12:08 AM | #3 | |
COTW [4/23/12]
oh okay. i thought i need to buy a new setup for the lights. thanks sapper12b
08-28-2013, 10:37 AM | #4 |
Drives: 2010 Camaro LLT/RS Join Date: Apr 2012
You may need to have your body shop cut the ports slightly to make them fit. I know that that is what has to be done with the Rideskinz fascia
08-28-2013, 11:08 PM | #5 | |
COTW [4/23/12]
oh okay then. thanks for the input.
08-28-2013, 11:42 PM | #6 |
Drives: SS, ZL1, V6 Join Date: Jan 2012
Looks like you'll have to cut a notch into the top, middle and bottom in order for the LED's to fit
08-29-2013, 12:53 AM | #7 | |
COTW [4/23/12]
hehe rideskinz. thanks for visiting my thread. so if i cut the top bottom and middle it'll fit perfectly?
08-29-2013, 07:13 PM | #8 |
Judging by the pics, I'm not sure if you'll have enough material to cut out the notches the same depth as the LED. Notching the ports might make it weak and cause it to deform. You can try to mount the LED's behind the ports without notching. Are you also installing mesh or leaving it open?
08-29-2013, 07:34 PM | #9 |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
Just contact Joe at ACS, he'll have the corect answer for you I'm sure.
08-31-2013, 05:16 PM | #10 | |
COTW [4/23/12]
i did.. finally they answered my question, they came out with a new setup of light for t4 ports.
