Old 09-16-2013, 08:05 PM   #1
TheAviator
Drives: 2012 Black Camaro 1LT
Opinions on price for custom leather job
The dealer recommended a guy that removes the cloth from your seats and replaces it with a custom leather job. For an LT. Quoted $1490, does that sound like a good deal? They will look basically like 2LT leather seats, Im getting solid black, of course.
TheAviator is offline   Reply With Quote
Old 09-16-2013, 08:15 PM   #2
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
If I was you I'd get used OEM leather seats...that way you know they are of good quality and your resale will probably be better. Also they will be cheaper most likely.
San2cci is offline   Reply With Quote
Old 09-16-2013, 08:24 PM   #3
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
It's probably Katzkin... supposedly as high of quality as OEM, but the key is getting a good installation. I've seen some sloppy fitting aftermarket leather, and have seen some great jobs too. I've even seen factory covers installed as a replacement to cloth with lousy, loose fitting results, so I'm sure a good installer is key for a nice, tight fitting, factory appearing job.
joeybsyc is offline   Reply With Quote
Old 09-16-2013, 08:33 PM   #4
San2cci
San2cci's Avatar
http://www.ebay.com/itm/10-12-Camaro...t_31461wt_1354
Old 09-16-2013, 08:33 PM   #5
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
http://katzkin.com
AmericanMuscleCars is offline   Reply With Quote
Old 09-16-2013, 10:23 PM   #6
RoadieWingZ
RoadieWingZ's Avatar
Drives: 2013 Black Camaro 1LS
Can sometimes find low mileage used OEM leather seats for about $600 +/-
2013 Camaro LS
RoadieWingZ is offline   Reply With Quote
Old 09-16-2013, 11:10 PM   #7
SS785
SS785's Avatar
Drives: Camaro SS
I've had aftermarket and oem. Honestly, go aftermarket.
SS785 is offline   Reply With Quote
Old 09-18-2013, 01:03 PM   #8
Mikes_L99
Drives: Camaro
used oem isn't a bad option for the money
Mikes_L99 is offline   Reply With Quote
Old 09-18-2013, 01:15 PM   #9
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
It's too bad your car isn't a convertible. I have black leather take off's from my 2013 Camaro convt. that I'd like to move.
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
Bowtie-Bri is offline   Reply With Quote
Old 09-18-2013, 11:15 PM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Iv had this done at a dealership. for that price you get Katzkin with the same leather content as OEM. They will not fit as tight as oem as they are made in bulk. I got a qoute from the dealer and told them I wanted 100% leather and they said they were. I had custom embroidery done on them and when I picked my truck up I saw they were vinyl. the dealer had to replace them with 100% leather embroidery and installation and eat the cost.
these are the 100% leather. Id go to a custom interior or audio store. Thats what the dealer did. The dealer calls a local kazkin dealer and orders them through them then has them come out and install it. I could have had it done a lot cheaper if I had gone right to the place they had do it.
JCunningham is offline   Reply With Quote
Old 09-18-2013, 11:25 PM   #11
JCunningham
Drives: 2017 2SS M6
http://www.ebay.com/itm/2010-2013-CH...948512&vxp=mtr price for instal is usualy $250 -$300
Old 09-19-2013, 01:51 AM   #12
StephenS_84
Drives: 2011 2SS/RS
OEM seat aren't 100% leather. Go aftermarket.
StephenS_84 is offline   Reply With Quote
Old 09-19-2013, 01:59 AM   #13
JCunningham
Drives: 2017 2SS M6
most aftermarket are not 100% either. you have to custom order 100%. this place will do 100% https://www.leatherseats.com/vehicle...earSelect=2012
Old 09-19-2013, 08:27 AM   #14
PhilSS
PhilSS's Avatar
Drives: 2011 Camaro SS
I just bought a 2012 maxima with the old lady. The dealer had katskinz installed before they put it on the lot, and it is awesome. I'd prefer it to any factory leather unless you want factory heat.
PhilSS is offline   Reply With Quote
