10-08-2013, 08:24 AM | #1 |
Carbon Fiber UV Protection
oh so heres my delema, i have a few carbon fiber exterion bits. One in perticular i have been having issues with the clear or resen or whatever it is clouding up after a farely short time (a few months). Now the company that i have purchased it from has replaced the part once already but im having the same issue again. and again the company is replacing it free of charge. I couldnt ask for better customer service.
is there some sort of UV protectant that can be put on these exterior bits to help protect them? i mean its great that they keep being replaced but at the same time if i can prevent that from happening i would like to. i was told to just wash and wax like i usually do, but if there is something specific i can do? |
10-08-2013, 11:13 AM | #2 |
Drives: 2012 AGM SS Join Date: Jun 2012
How soon are you waxing as compared to when it's made? If you don't let the clear coat on top properly cure you could be causing it. I would treat it the same as any paint, give it 30-90 days before waxing or sealing.
If this is not the case then it's a production problem where the carbon fiber is the issue, which since it's under the clear coat you can't really do much about it.
10-08-2013, 11:17 AM | #3 |
Drives: ( . )( . ) Join Date: Feb 2010
Just get them clear coated with a good automotive clear coat, they are UV resistant.
also ask them what type of resin they are using, some resins will yellow over time and some resins are UV resistant, they obviously need to use UV resistant resin for exterior pieces. Can you post a picture?
10-08-2013, 11:35 AM | #4 | ||
