10-13-2013, 11:56 PM | #1 |
Goodyears from Discount Tire
Discount Tire had these tires for $2 less than Tirerack.com and the installation was about a third of the standard Tirerack fee. What's more is the crew at Discount will even autograph your wheels! Job well done, I say.
10-14-2013, 12:44 AM | #2 | |
Loves Camaros
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1! Join Date: Sep 2012
What the heck did they do to your wheel(s)??? I bought two Goodyear F1's last year just in case of catastrophic failure from Discount Tire. They're still in my garage. They'll be the first two on when I have my currents worn out. Learning from your experience, I probably won't get them installed at Discount. Is your Discount Tire store going to make good on repairing your wheel(s?) Thanks, Tara
Old and new, sharing space!
10-14-2013, 12:47 AM | #3 |
Looks like they pried off the old weights with a screwdriver rather than something made out of plastic.
I'm going to go in tomorrow and suggest a few ideas I had to make it right. Hopefully we can find an amicable solution and I won't have to go to small claims court. |
10-14-2013, 01:18 AM | #4 | |
Loves Camaros
I hope it works out well for you. These wheels are darned expensive, and I would really be upset if this happened to me. I had a flat repaired and patched by a close friend's shop where he works on a lot of exotics. The guys took a lot of care while de-mounting and mounting the tire on the rim. Then I caught them trying to use an air tool to tighten the lugnuts! I jumped out there and made them use a torque wrench and tighten by hand. Goes to show that you can hardly trust anyone with your ride... Good luck with yours! Tara
10-14-2013, 06:40 AM | #5 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
From the look of the second pic, they didn't even remove all of the old adhesive when they removed the original weights.
Piss poor workmanship. Good luck on your talk with the manager....
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
10-14-2013, 06:42 AM | #6 |
Drives: E92 BMW M3 Join Date: Oct 2012
The exact same thing happened to me. I havent had a chance to make it over there yet, but will likely make it this afternoon.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
10-14-2013, 08:28 AM | #7 |
Sellin Chevy's since '06
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
10-14-2013, 08:33 AM | #8 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Wow. I have used discount tire locally several times without an issue.
10-14-2013, 08:38 AM | #9 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
People would get hurt...
10-14-2013, 09:39 AM | #10 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
I guess wherever we go we have to keep a close eye on everything they do or what?
10-14-2013, 10:00 AM | #11 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
This is not a Discount Tire thing as it could happen anywhere...This is an employee that was not trained or didn't care. It doesn't matter who did it the shop is still responsible for the damage.
Call it anal, OCD or just experience, but I always walk around any car I own before it leaves the dealer lot/tire lot. ..It is much easier to point out an issue at the time you pick it up vs after you leave. I even to a quick scan for door dings every time I leave a car in a parking because if the person (car) is still there you can get their info and their insurance will pay for the damage (at least in Michigan, a no-fault state) Matt
10-14-2013, 10:16 AM | #12 | |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
10-14-2013, 10:31 AM | #13 |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Oct 2013
The american education system at its best....as well as hiring to meet quotas instead of skill.
10-14-2013, 11:13 AM | #14 | |
Drives: 2013 Camaro SS 1LE Join Date: Jul 2013
