11-02-2013, 12:23 AM | #1 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Light chirping sound from wheels at 25-30 mph!
I often hear this sound from the left side of my car. It's faint. Started now on the right side. Goes away when I brake or slow down so I'm not convinced it quiets from baking alone.
Plus, I checked the brake wear indicators and I'm nowhere near the rotor. I'm afraid to get service at my dealer. They swapped my splitter early on and didn't fully reassemble all the locking clips. I had to buy 8 locking clips at 3.30 each. My tennis partner drives a Volt and they kept his car for over two days to change the oil. And my old boss had biz Vetter there for a started and they kept it over a week. Sent from my iPad using Tapatalk HD
11-02-2013, 10:23 AM | #2 |
Do you have the stock tires?
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe 2002 35th Aniversary SLP SS-Sold |
11-02-2013, 12:54 PM | #3 |
Drives: Camaro Join Date: Sep 2013
A
11-02-2013, 05:49 PM | #4 |
Angry by Nature
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76 Join Date: Aug 2013
If its a rotational chirping noise it could be the pads themselves. Might have heat cracks. Also could be the rotor backing plate. Sometimes they can get moved around and contact rotor and make noise at certain speeds.
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP 1 OF 76 Roto Fab CAI 1LE BADGES |
11-02-2013, 07:27 PM | #5 |
Drives: Want a gen 6 Join Date: Jan 2013
Uh isn't chirping 2nd in the cold normal?
11-03-2013, 11:12 AM | #6 |
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
11-03-2013, 07:35 PM | #7 |
11-03-2013, 07:35 PM | #8 |
11-03-2013, 07:42 PM | #9 |
If it happens when your shifting that's normal at rpms anywhere down to 2500rpm.
11-03-2013, 08:18 PM | #10 |
Angry by Nature
If it was me I would do a brake inspection on it, pull the pads and check them, just give it all a general look over.
11-03-2013, 09:08 PM | #11 |
11-03-2013, 09:08 PM | #12 |
11-04-2013, 10:16 AM | #13 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Check for rotor warp while you are there. it will be cyclic in sound and most times the stopping will be "jerky"
11-04-2013, 01:43 PM | #14 |
Angry by Nature
Using a dial indicator properly set up check radial runout of the rotor, I'm sure someone can find the spec for you. Does the brake pedal or steering wheel pulsate during braking?
