12-05-2013, 10:40 PM | #1 |
Drives: 2013 1LT/RS Join Date: Jul 2013
Rough Idle on a 2013 V6
Was just wondering, anyone having rough idle? Very noticeable at start up. Dealer says they (V6) all do it, no error codes. Started once in awhile when new, but now (5000 miles) does it every start up.
I don't want any trouble down the road... Thanks for info |
12-05-2013, 11:30 PM | #2 |
Drives: 2013 2LS BLK Join Date: Oct 2013
I have 8000 miles on mine and yes I do notice a rough idle. I've heard the vmax ported throttle body can help eliminate it I will let you know when I get one!
12-05-2013, 11:44 PM | #3 |
Thanks...
12-06-2013, 12:35 AM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
Mine idles smooth cold, but has a rough idle sometimes when it is warm. It isn't bad, but noticeable when stopped in traffic. The Vmax PTB didn't make a noticeable improvement for my car.
12-06-2013, 08:00 AM | #5 |
I notice the same thing on my 12 LFX
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
12-06-2013, 08:20 AM | #6 |
BlueDiamond
Drives: 2015 2SS 1LE RRM Join Date: May 2013
I have a 2013 2LT and really have not notice any , can you put up a vid of it
good luck! |
12-06-2013, 08:25 AM | #7 |
Drives: 2013 DUSK Special Edition Join Date: Sep 2012
My 2013 has done this since new. Have 3000 mi now. Service dept can't find anything wrong.
1 of 56
12-06-2013, 08:46 AM | #8 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Yeah, if you could describe it further, or with parameters, that would help us help you.
12-06-2013, 08:49 AM | #9 |
mine starts rough/loud then smoothens out..but probably more noticeable w/ the cherry bomb exhaust system
12-06-2013, 09:21 AM | #10 |
I'll get some more info, vid soon. Thanks for the feed back so far.
12-06-2013, 09:41 AM | #11 |
Drives: 2012 Crystal Red Tintcoat RS Join Date: Apr 2013
2012 LFX 10,000 Miles. Rough idle when cold, and a little rough when warm. I accredit it to 11.5 to 1 compression ratio. Sound more like a car that had some cam work.
Installed Vmax PTB and acceleration is much smoother. No lag when you accelerate lightly. Haven't got on it yet. Maybe adding a CAI would help it breath better. |
12-06-2013, 03:46 PM | #12 |
Yeah, my car, for example, only starts rough (as in a stronger than usual jolt) when cold, but otherwise idles fine.
12-06-2013, 03:50 PM | #13 |
Black Mamba
Drives: 2013 2LT RS Join Date: Feb 2013
Mine did it a couple of times when the temp got really cold. It took quite some time for the idle to become smoother, but i just thought it was because it was warming up.
2013 2LT RS "Black Mamba"
Heritage Grille | Gen5DIY Halo & DRL Harness | LEDs - DRLs, dome, trunk, license plate | ZL1 rear and RPI front splash guards | CAI Inc. Cold Air Intake Elite Engineering Catch Can | Oracle Ghosted Sidemarkers | FR ZL1 style wheels | VMax Black Ported TB |
12-06-2013, 09:53 PM | #14 |
Optimus Prime
Drives: Camaro ZLS [COTW 09/22/14] Join Date: Dec 2012
Mine did it today at the light, I did race my friends truck when he tried to test me.. I have a 2013 also...
