Old 12-05-2013, 11:46 PM   #1
dangnplus
dangnplus's Avatar
Drives: 1LT camaro RS package
Engine light came on?
When I got out of work, the tempt dropped to 25 degrees and noticed my tires were 29/29/30/30 is it normal for my tire PSI to drop so low? an flash engine light also came on, here are the photos.
NOTE: the driver side PSI kept flashing at 29.
dangnplus is offline   Reply With Quote
Old 12-06-2013, 01:13 AM   #2
Cooman0007
Drives: 1LE
I see 28 lol. It's Its normal for tire pressure to drop alittle during cold weather
The light I see on is the tire inflation indictor. I'm assuming its because your front left tire has dropped out of recommend spec. Air all tires back to specs and see of that takes care of the light. As far as that front left tire I would take a bottle fill it with water/dawn soap and spray it down and look for bubbles just to be on they have safe side.
Cooman0007 is offline   Reply With Quote
Old 12-06-2013, 01:18 AM   #3
dangnplus
dangnplus's Avatar
Has anyone else have the lights come on due to low psi in the winter?
Old 12-06-2013, 01:18 AM   #4
dangnplus
dangnplus's Avatar
Thank you! I was worried something was wrong with my car
Old 12-06-2013, 01:27 AM   #5
Cooman0007
Drives: 1LE
Ur welcome
Old 12-06-2013, 01:33 AM   #6
Vengeance Graphix
Vengeance Graphix's Avatar
yup my tire light sensor turns on usually mid November when it gets really cold. My tires usually drop to the 28-29 range as well
Old 12-06-2013, 02:33 AM   #7
dangnplus
dangnplus's Avatar
Glad to hear I'm not the only one! Tempture has gotten to 10 degrees here, hopefully my camaro can make it back & forth to work in these harsh roads.
