Old 12-16-2013, 11:48 PM   #1
Victoryred1le
Bupp Motorsports
Victoryred1le's Avatar
Drives: 2017 Summit White ZL1 A10
need slave cylinder recomendations
well after 8700 miles the slave cylinder gave out in my 13' 1le. Is there an upgraded slave I can go to instead of the stock gm junk. MY car makes 476/424 at the wheels so im going to replace the clutch while im in there. Thanks in advance.
Victoryred1le is offline   Reply With Quote
Old 12-17-2013, 08:15 PM   #2
Steve@SNL/Monster Clutch
Drives: 2014 SS
The factory slave cylinder in these cars are hit and miss. The new LT1-S twin disc we offer has a lighter pedal that stock which will put less stress on the slave cylinder assembly.
I shot you a PM, let me know if you have any questions and merry Christmas!
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 12-17-2013, 09:12 PM   #3
GFORCE1320
Drives: 05 GTO
What would you recommend Steve, just keep a stock slave in it or aftermarket? I get asked this question as well.
GFORCE1320 is offline   Reply With Quote
Old 12-17-2013, 09:56 PM   #4
Drives: 2014 SS
Honestly man, factory. There isn't a single aftermarket slave cylinder that I've seen that could stand up as well as the setup from GM. Sure, they may displace more fluid, be adjustable, etc. but in the end they just don't last.
When the fluid is maintained and you can reduce the bearing load (I.E. the amount of force that is applied to the release bearing - which makes for a less stiffer clutch) you increase the life of the part. Will there be failures of the factory setups? Sure. Are they complete garbage? No. But until I see a legitimate slave setup that will work I'm not convinced.
Old 12-18-2013, 07:21 AM   #5
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Best Thing to do is keep the stock slave cylinder and just change the Throw out bearing. The Gm plastic throw out bearing are junk.
IDEALG is offline   Reply With Quote
Old 12-18-2013, 09:38 AM   #6
H-E
Drives: 2010 zr1 Camaro 2011 vert
H-E is offline   Reply With Quote
Old 07-07-2014, 04:02 PM   #7
WiredAVS
WiredAVS's Avatar
Drives: '21 TRx '22 ZLe
Is there an upgraded bearing? This weekend after some "spirited driving" I now have developed a pulsing when I apply slight pressure to the pedal. The pulsing is only at the 1st 1/2" of pedal travel. Once you get past that, the pedal is smooth. The pulsing is in sync with the rotation of the engine/flywheel. I assume its the TO going amuck. Stock clutch isn't slipping "yet".
Looking at the:
Monster Level II Street Twin
Mantic 9000
Street Slayer
Already have the remote GTO reservoir and keep fluid clean, looking to change over to s/s Lines to slave, adding remote bleeder, and going to coat the headers to help get the heat down away from the line.
What I don't want to do is pull the clutch, replace everything, and have this stupid plastic bearing going to crap again.....With my luck it would take out my new clutch in the process.
2014 Camaro 2SS/1LE AGM/768rwhp
Recaro's, Custom Autometer Gauges, Hotchkis 1" Lowering Coils, CAi Intake, Elite Catch Can's, 1 7/8" StainlessWorks LT's w/Hi Flo Cat's mated to factory NPP Exhaust, 160* Thermo, NightFury Cam, 2.9l Whipple on Meth @ 11lbs, JoeGibbs LS30 in the CrankCase, Built by Nick, Steven, and Tuned By Shawn at Lethal Racing....
WiredAVS is offline   Reply With Quote
Old 07-07-2014, 04:36 PM   #8
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
blew out my twin disc at 9000 miles...went 4l80...to much headache blowing these out..happens to easy with bigger hp cars...not worth the headache when you blow one out 800 miles from home
mikepage0007 is offline   Reply With Quote
Old 07-07-2014, 05:52 PM   #9
H-E
Looking at the:
Mantic 9000
Street Slayer
Thanks for the order!
Old 07-07-2014, 06:19 PM   #10
H-E
If you buy the right clutch you don't have issues ..How you been man!
Old 07-10-2014, 08:21 AM   #11
SpaldCam
Drives: 2011 Camaro 2SS/RS
Looking at the:
Mantic 9000
Street Slayer
I just noticed this on my car as well. I brought it into the shop about a month ago complaining about rough clutch engagement and was told it was performing like every other Camaro they had ever driven. The bearing was just noisy.
Now I get pulsating grinding for the first 1 or 2 inches, then smooth, then grinding pulsing with the clutch all the way in. I'm also getting pulsing as I let the clutch out. I'm worried this is prematurely wearing the clutch disc and flywheel. It's more difficult to push the clutch in while moving, sometimes, it feels like I'm doing leg presses.
The worst part is they just replaced the clutch 1000 miles ago. I babied this thing to break in the clutch. If the bearing is severely worn I could need a whole new clutch again!
SpaldCam is offline   Reply With Quote
Old 07-10-2014, 04:35 PM   #12
WiredAVS
WiredAVS's Avatar
I would assume that whomever you had replace the clutch would look at this under their warranty. If they replaced the clutch, then the slave and bearing usually get changed out at the same time. Have you brought it back to the installing party?
I have not removed the tranny yet to determine the root cause of my pulsing as I'm waiting on parts. As soon as it's down I'll report the cause. Should be within the next few weeks.
ePhone
