12-25-2013, 04:44 PM | #1 |
Drives: 2011 1SS/RS LS3 Join Date: Dec 2012
p13W bulbs from Gen5diy don't fit??
Merry Christmas!
Today, I received a set of p13w DRL bulbs (11 watt, 5000k) from gen5diy.com and I can't for the life of me get them to fit in the DRL "hole". They look the same as the old bulb (the black part), but it seems they simply don't fit in the same orientation as the old bulb. Is there something simple I'm doing wrong?? Thanks!
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways |
12-25-2013, 04:56 PM | #2 |
I went through the same thing last year trying to get them for my 2011 1LTRS/RS i bought a set from Phastek that didn't fit.Go to ebay,but dont buy the ones that come from China,they fried my wire harness.I got mine through i think motoringmax,they fit and are cheaper.
12-25-2013, 05:40 PM | #3 |
Drives: 2012 IBM 2SS Vert. Join Date: Dec 2011
Did you compare them to the ones you took out? There was a change in the bulb itself,IIRC it was late 2011 early 2012.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
12-25-2013, 07:21 PM | #4 |
Drives: 2012 45th Edition 2LT RS,2005 Tahoe Join Date: Mar 2012
Have you contacted Gen5diy? The bulbs changed in 2012, if it's the wrong bulbs I'm sure he will exchange them.
12-25-2013, 07:30 PM | #5 |
having FUN now 13.66@101
Verify that the rubber gasket from the old bulb is not left on the light housing. That happened to me on one of my bulbs and I could not get the new bulb into place. I noticed it when comparing the bulbs.
12-25-2013, 08:54 PM | #6 |
Drives: 2013 ZL1 Join Date: Jun 2013
Check the little plastic keys, there is one that needs to be dremeled off I had the same problem and that worked for me
12-25-2013, 10:15 PM | #7 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
In late 2012 and all 2013's+ come with PSX26W bulbs instead of the 2010-early 2012 models that came with the P13W. Read the connector housing on your factory bulb. You should be able to read they bulb type on that. Or check your owners manual and it may list it in there as well.
12-26-2013, 12:14 PM | #8 |
Thanks for the advice guys! I looked closely to today and my old bulbs are imprinted with "SP13W" instead of just P13W... this is the first I've heard of an SP13w bulb. Is there a different HID bulb available in SP13W?? Or is sp13w considered to just be p13w? Or should I just try to take a dremel ever so slightly to the prongs which seems to be angled the wrong way? Thanks again!
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways Last edited by Bmatth1162; 12-26-2013 at 09:32 PM. |
12-26-2013, 12:30 PM | #9 |
Ah DJ-IOM ZL1 haha
Drives: 13 IOM ZL1 M6 & 10 SIM 2SS M6 Join Date: Jul 2009
The biggest issue is the rubber gasket on the bulb. Just take the rubber gasket off of the old bulb and put it on the new one and the bulb will slide in without an issue.
2013 IOM ZL1 #002415 Born 09/13/12
2010 SIM 2SS/RS #005549 Born 05/02/09 |
12-26-2013, 12:35 PM | #10 |
Drives: 2012 45th Camaro, 2SS/M6 Join Date: Mar 2011
i have been having the same problem, and i don't have a dremel which doesn't help.
edit: decided to give up on them altogether. maybe someone else will have the right tools to make them work. Last edited by kiteman; 01-08-2014 at 06:19 PM. |
12-26-2013, 01:53 PM | #11 |
Thank you all for the help. After a day full of headaches and dremel-ing and a few beers I finally got my bulbs to work with the DRL harness and am very happy with the brightness and color match. Kiteman I'm sorry you were having trouble too. I just got the 5000k 11watt from gen5diy and the color match is great. Mine were a nightmare to fit (all 3 prongs needed to be adjusted to fit the housing) but I love the color match, give them a shot if you don't mind a little drill work Sent from my abacus
01-09-2014, 09:57 AM | #12 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Guys, if your bulb does not fit then send it back we will refund the sale, but if all 3 tabs are not fitting we think you need the the other bulb, there in no way they dont fit, we have sold over 2K sets of bulbs and get this ones in a long time,
01-10-2014, 11:11 PM | #13 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
Mine fit without issue Ofer!
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
