Old 12-26-2013, 08:36 PM   #1
Zachreed89
Drives: 2010 camaro SS
NEED HELP FAST
I have a 2010 camaro ss..
Mods:
LMR TUBING WITH K&N FILTER CAI
XPIPE
BORLA AXLE BAK S TYPE
I cleaned the oval K&N filter, oiled it and let it soak overnight.. About a week after I did it the CEL came on and the codes said I was running lean in bank 1 and 2.. I looked around and it said that oil may have gotten on the MAF so I cleaned it re installed and everything was good.. Well the car say for 2 days while I was out of town and I drove back home and the CEL came back on but when I got home unpacked the car and pulled out my obdII monitor the CEL was off... So I read more and something was said about pulling the #5 and #20 fuse to reset the mapping for air and fuel.. I'm trying that now and we will see how it works tomorrow but I planned on getting a street tune from a guy in cedar park, tx.. I heard that can fix the issue but I was wondering if anyone w
Else had this issue... So lost in the sauce right now any help will do thanks in advance
Zachreed89 is offline   Reply With Quote
Old 12-26-2013, 09:56 PM   #2
LeanPocket
Drives: 2010 2SS
It's the k&n oil messing with the maf
LeanPocket is offline   Reply With Quote
Old 12-26-2013, 10:03 PM   #3
Blown 386
Drives: 2010 victory red 2SS/RS
Since you just cleaned your filter, it could have been to much oil sprayed on the filter. Those kind of filters only need a light coat of oil. To much and it gets sucked through the element and ends up on the mass air. You might check your element for over saturation.
Blown 386 is offline   Reply With Quote
Old 12-26-2013, 10:08 PM   #4
BDBiker
BDBiker's Avatar
Drives: Black 2013 2SS/RS 1LE
Good advice above, those filters need very little oil.
BDBiker is offline   Reply With Quote
Old 12-26-2013, 11:49 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Switch to a dry filter...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-27-2013, 12:03 AM   #6
Zachreed89
I hear oil is better.. But like I said it's what I heard... When I picked up the car I'm pretty sure they put 87 octane in it but it only popped up when I cleaned the filter out which might I add was filthy as f**k.. Didn't throw CEL until I cleaned and added oil.. Any recommendations for a dry filter?
Old 12-27-2013, 01:25 AM   #7
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Afe, airaid, Aem...all have dry filters sold individually
-John S.
