01-05-2014, 02:31 PM | #1 |
Drives: 2010 Camaro 2SS - Black on Black Join Date: Aug 2010
Review and How-To: Adams Rinseless Car Wash
Intro:
I was lucky enough to get a sample of this product a few months back to test and provide feedback to Adams. I am a big fan of rinseless washing in general, so I was pumped when I heard Adams was stepping into this category and looked forward to the opportunity to review their new product. I prefer using multiple plush towels in one bucket of solution instead of using two buckets and grit guards (as Adams recommends). I personally like this method better because it assures you are always working with a clean wash media and your wash solution never gets contaminated. Therefore, the how-to portion of this review will be based on my preferred method. By all means, please use the method you feel most comfortable with when doing a rinseless wash because the same results can be achieved either way. The car was two bucket washed and waxed about 3 weeks prior to this review and has since been in the garage collecting dust. It was taken for a quick drive the day before this review so it has a nice layer of dust and possibly a little road grime. Below is a pic of the general condition of the paint before starting. Given the car is not filthy and since the outside temp. was around 35 degrees, a traditional two bucket wash is unnecessary and uncomfortable. This is the ideal situation for a rinseless wash and it can be done in the controlled environment of your garage. You save time, effort and resources without freezing your buns off. How To: - Start with a bucket of clean water and add 2 oz of rinseless wash. I like to use warm water during the cold months. - Mix the solution with your hand or grit guard. - Add several plush towels to your solution and make sure they submerge and soak completely for a few minutes. - Remove a towel and fold it into quarters letting most of the excess solution drip back into the bucket. - Divide the car into sections and start at the top of the vehicle making light straight line passes over the area with one side of the towel. - Inspect the towel often and rearrange and reflip the towel as needed to ensure you are always working with a clean side. - Once the towel is completely soiled, wring it out and retire it from this wash. - At this point you need to dry the area you have just cleaned. A quick wipedown with your drying towel should knock out the residue and leave a streak free shine. - Repeat this process around the car using a new towel as needed. For reference, I used 5 towels on my Camaro and it took around a half hour to complete. As long as you use proper judgement, quality microfiber and good technique, your paint will stay as swirl free as possible. - Use the remaining wash solution and some lower grade towels to do the dirty areas of your car last - like wheels, exhaust tips, etc. You can use your brushes and such just like you do with soap or wheel cleaners. Obviously this can only be done safely and effectively if the car is only lightly soiled. This stuff is not designed to clean heavy grime and brake dust. Review: My thoughts on the product were nothing but positive. I love the smell, color and performance. It is definitely on par or better than the leading brands in this category because it cleans well, wipes away easily and leaves a little protection and just waxed look. The dilution ratios are comparable to other brands and it can also be used as a waterless wash and clay lube. The only negative I could think of would be the cost per use as compared to the other brands but if your buying and using Adams, your already fully aware its not going to be the cheapest option. But you know its a quality product and its backed with a 110% guarantee. And surely they will offer it in larger sizes than 16 oz soon... Overall I give the product two thumbs up and would recommend it to anyone looking for an easy and safe alternative to the traditional two bucket wash for lightly soiled vehicles. |
01-05-2014, 02:44 PM | #2 |
I bought a bottle of this a couple of weeks ago and still haven't tried it out. Looks very easy with good results. Nice write up!
01-05-2014, 06:50 PM | #3 |
Thanks man, I think you will like the product. Quickest way to safely clean your car and avoid the elements.
01-05-2014, 07:19 PM | #4 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
All I have to say is that it was very enjoyable washing my car yesterday in the 65-70 degree weather here in AZ.
Detailing is an involuntary obsession.
01-06-2014, 11:42 AM | #5 | |
I hate you. |
01-06-2014, 12:23 PM | #6 |
Great review.
Sent from my HTC One using Tapatalk 2
[B]
01-06-2014, 02:41 PM | #7 |
Drives: The shiny ones. Join Date: Mar 2010
Thanks again for the review and for posting it over here!!
01-06-2014, 06:46 PM | #8 |
Thanks gentlemen. Just used it again last night, my garage smells great today! |
01-06-2014, 10:45 PM | #9 |
Drives: Eastbound and Down Join Date: May 2012
Thanks for the review. It sounds great. I still have half a gallon of ONR to finish off, before I pick up more rinsless wash.
01-06-2014, 11:25 PM | #10 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Thanks for the review. Would you prefer this over onr and why?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
01-07-2014, 08:16 AM | #11 | |
I would definitely prefer this over the original ONR because it wipes away easier and leaves a little protection. My original ONR is now used for clay lube and prespraying panels. I would say its very comparable to ONRWW. I need some more time with it to identify the minor differences between the two performance wise. |
01-07-2014, 08:50 AM | #12 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Good info; Subscribed, thanks.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
Thread Tools | |
