![]() Drives: 2013 SS Join Date: May 2011
Some thoughts on autox and such
Been thinking about trying autox again this year. I've been out of it for about 7 years now. I used to hit a lot of track days and won a couple of regional solo2 championships back when a C4 corvette was still in SS.
I got a camaro because I have a now 8 year old son and wanted to get something with a back seat that we can all enjoy and take day trips in and such. All that said... Tell me if I'm wrong but I ran some figures. at 3000rpm most LS3 cars stock are about 330rwtrq. 330 x 2.07(2nd gear ratio standard SS) x 3.45 (final gear in standard SS) = 2356 For a 1LE 330 x 1.78 (1LE 2ND gear) x 3.91 = 2296 I use 2nd gear because thats where you should spend most of your time on most courses. For comparison. MT82 faound in the Mustang has 2.43 2nd gear ratio. Assuming they dyno 325rwtrq 325 x 2.43 x 3.31 = 2614 Just something to consider. I know we have IRS and a bit wider tire but we are heavier and with less power at the wheels. I think this also explains some of the disparity at the drag strip too. Just wondering if anyone else had thought of this. I'll post up results from any autox events I make it to this year with observations. I've had this car on a road course once so far on street tires and it did about what I expected (I had pretty high expectations). We'll see if that holds up at autox.
2013 model 2SS LS3
1969 model wife. Factory stock, no mods. Redhead package. 2005 model son. Special ordered with the hell on wheels package. |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Offhand, I suspect that car weight relative to tire tread width will be at least as important as rear wheel traction to car weight, assuming that everybody is able to keep the tires cambered somewhere near right in the turns.
I prefer to use rear wheel traction rather than rw torque because the tire sizes are a bit different as well (about 27" Mustang, 28.6" SS, 27.9" 1LE). Norm |
Norm, I thought about that too. Theres no 'real' way that I can see other than mixing it up on course to see what really happens though. I'd think that the ability to dial in more camber/toe/castor with the SS IRS may help with that some.
Interesting point about the traction. When you figure tire height the torque gets worse for the SS and 1le and the mustang pulls away even further. However, the mustang is limited by tire size more so than the SS so they may be into wheel spin much sooner.
2013 model 2SS LS3
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Put 305 all around it will handle like it is on rails
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
I cant fit a 305 on the stock front wheel. I am NOT going to play the "throw cubic dollars at it game" and go to a modified class just yet. In stock class you are allowed to go down in wheel diameter 1" but must keep the same offset and width.
I don't mind running street tires as long as everyone else is too. That's a level playing field and it looks like the SCCA is going to go to a 200 tread wear for stock classes. If that's the case I may give it a try again.
2013 model 2SS LS3
#6 |
Casey Woodside
Then get the same width tire on all four corners and it will handle a lot better
#7 |
Are you saying to put a 275 on an 8 inch wide front wheel?
![]() Not gonna happen.
2013 model 2SS LS3
#8 |
![]() Drives: Chevrolet Join Date: Jan 2014
#9 | |
The current Mustang can end up handicapped on the more open courses by axle ratio options that are too short to allow the driver to stay in the MT82's 2nd gear. Even 3.55's can force 2-3-2 shifting that typically ends up costing time. The downside of overall gearing chosen for street "sparkle" and occasional dragstrip use with a relatively small-displacement engine, I guess. Norm |
