02-11-2014, 07:05 PM | #1 |
Drippin' Wet Auto Detail
Remote start for manual
I'm looking to get an after market remote start for my manual 2012 SS. I believe they have had a lot of advancements in remote starts for manual shift.
Any ideas on the best ones out there and how they work? Thanks! |
02-11-2014, 07:11 PM | #2 |
Car Enthusiast
Drives: 2010 Rally Yellow Camaro 2SS A/T Join Date: Dec 2010
this may help
http://www.camaro5.com/forums/showth...t=19983&page=2 http://www.camaro5.com/forums/showthread.php?t=333815
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016 |
02-11-2014, 07:19 PM | #3 |
Drives: 2013 2SS Blue Ray Metallic Join Date: Feb 2014
They are a little strange. My wife has one on her Mazda 3. You have to put the car in neutral, pull the parking brake up twice and then exit the car while it is still running. As soon as you shut the door the engine shuts off and sets the remote starter. It cost about $500.
02-11-2014, 07:38 PM | #4 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
No valet for me. Everytime I hear the word all I think about is that airborne 61 Ferrari GT in Ferris Bueller's Day off with those two guys big Ol grins.
Besides, I like to hear that rough, racecar cold start with headers, so no remote start for me.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
02-11-2014, 07:52 PM | #5 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Do you park with the emergency brake on? If so, you shouldn't. It's a cable and it's only a matter of time before you stretch that cable out enough and it snaps, sending your now free-rolling vehicle (it can't possibly be in gear if you're considering remote-start) down whatever slight incline it happens to be parked on.
Park your manual vehicle the same way you do an automatic, in gear (first or reverse works quite well). This of course, prevents the possibility of remote-start, but that is the price of transmission greatness. |
02-11-2014, 09:07 PM | #6 |
Drives: 2012 2LS Inferno Orange Join Date: Mar 2012
http://www.camaro5.com/forums/showthread.php?t=321652 check this out install you can do yourself
02-12-2014, 06:33 AM | #7 |
Drives: 2013 1LS, 2013 Ram 1500 Join Date: Mar 2013
i have been running compustars since they came out in the early 2000's. they are the pioneer in the manual remote start. i would use them any day and feel safe. however DONT use it if you are one that leaves their windows down or if you have a convert. i have never seen any issue with them.
02-12-2014, 06:59 AM | #8 |
SSmokinJoe
Drives: 2010 SIM 1SS/RS M6 Join Date: Feb 2010
Wow, that's interesting. I've been driving a manual for 10+ years and never knew there was a remote start available.
1SS/RS Silver with Black Rally Stripes.
35% Tint Roto-Fab CAI SLP Loudmouth II Axleback Hurst Shifter R1Concepts Slotted Rotors Hawk Ceramic Brakepads I drive way too fast to worry about my cholesterol. |
02-12-2014, 12:13 PM | #9 |
My brother had one on his car w a manual and he forgot to set his and he started it up and his car lunged forward and messed up his front end. After the second time this happened he disabled his. I wouldn't recommend it, you think you will set it. But like my bro, he forgot and it cost him.
02-15-2014, 05:28 PM | #10 | |
Drives: 2010 2SS Join Date: Feb 2014
First of all automatic transmissions have a park pawl that locks the driveshaft and the only way an automatic can go "in gear" is with hydraulic pressure that is created by a running engine turning a pump in the transmission. Yes using 1st or reverse on a manual trans will will give you the best gear reduction (or OD for the engine) but it will still slowly role down a hill if it is steep enough as engine compression bleeds off. Also not using your parking brake will result in corrosion locking up moving components. (e.g., parking brake cable, shoes, hardware, etc.) |
02-15-2014, 05:35 PM | #11 | |
02-15-2014, 07:58 PM | #12 | |
02-15-2014, 08:10 PM | #13 | |
BeckyD Rocks :-)
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
02-15-2014, 08:18 PM | #14 | |
BeckyD Rocks :-)
So, for those who are noobs, no need to crank the shit out of the e-brake when applying. Make sure to have it inspected every year you get your car inspected (part of the safety inspection in most states) and everything will be golden.
