Old 07-26-2009, 10:32 AM   #1
BLT4SPD
BLT4SPD's Avatar
Drives: 2010 SS, 2011 Z71, 1980 Camaro
Underdrive Pulleys
I'm asking the experts...DO or DON'T?
BLT4SPD is offline   Reply With Quote
Old 07-26-2009, 11:04 AM   #2
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
Do it. It is all about performance!
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 07-26-2009, 11:31 AM   #3
rodimus prime
Drives: Cargo van.
Id hit them up as the last of the bolt ons.
Def go CAI/Headers/Exhaust/ Intake Manifold first. You can swap pullies and not need a tune because nothing really changes.
rodimus prime is offline   Reply With Quote
Old 07-26-2009, 11:34 AM   #4
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
...just keep in mind that ALL of your accessories (Water pump, alternator,air conditioner, power steering) will be turning SLOWER, using less power, which is where the increase comes from.
patriotpa is offline   Reply With Quote
Old 07-26-2009, 11:57 AM   #5
BLT4SPD
BLT4SPD's Avatar
Already have ARH headers and exhaust and a tune waiting on Varraram CAI.I was concerned about turning the A/C and Alt. slower.All the driving is in town.
Old 07-26-2009, 12:04 PM   #6
rodimus prime
Drives: Cargo van.
It will be fine, unless you bought some aftermarket stereo amps and subs and went crazy.
Old 07-26-2009, 12:21 PM   #7
2010-1SS-IBM
Drives: 1998 Nissan, 2010 Camaro
Question: I'm hearing the stock air intake is already pretty good. Why would you put that among the first things to do, rather than one of the last?
2010-1SS-IBM is offline   Reply With Quote
Old 07-26-2009, 01:43 PM   #8
rodimus prime
Drives: Cargo van.
Because its not very good. The baffles are huge restrictions alone. When every vendor is claiming about 20hp off all the styles, it tells you the stock version is not good. BTW I looked at my car and the crank pulley looks like it will be a pita to pull off and install....especially compared to a CAI.
Old 08-14-2009, 09:11 PM   #9
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
So if i install an aftermarket underdrive pulley, it will take power away from alt, ac, power steering??? I dont get it.
Bentley78 is offline   Reply With Quote
Old 08-14-2009, 09:29 PM   #10
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
sort of. when you put an underdrive pulley on the crank, you need to put an overdrive pulley on the alt at the very least to ensure that you are keeping it spinning properly to power the battery.
I piss excellence
and fart awesomeness
Old 08-16-2009, 09:27 AM   #11
toehead93
Drives: 2014 2SS/1LE
I'll probably do it with a cam change, does anyone have dyno results for a pulley swap?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-16-2009, 10:51 AM   #12
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
I've got 25% pulleys and I don't notice any difference in the performance of the AC...and I live in Florida.
As far as the performance increase...I can't speak to it individually as all my current upgrades were done at the same time.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 03-17-2012 11:22 AM
Pulleys alex33x Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-09-2009 11:56 AM
underdrive pulleys drayton_cross 4th Generation Camaros 4 06-05-2009 01:04 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA V8 Bolt-Ons & Tunes 1 05-20-2009 11:40 AM
Underdrive pulleys SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 05-06-2009 05:43 PM
