JUICEDMOTORSPORTS
Old 07-27-2009, 12:55 PM   #1
navyflyer72
Drives: 2010 2SS/RS 6spd, BLK/CYB GRY
Sirius hook-up connection
Does anyone know if this Sirius FM adapter can be plugged into the head unit in our Camaro's? I am really trying hard to get my Sirius set up in the car and I though that this might work... another possibility might be an RCA plug-to-USB plug and plug my Stiletto 2 into the center console...
http://shop.sirius.com/edealinv/serv...2&oldParentID=
Thanks for any info any of you might have about the back of the head unit.
The Zac Hartwell & Ryan Dunn Tribute Camaro Project and Tour
Benefiting the Wounded Warrior Project & Garth Brooks Teammates for Kids
navyflyer72 is offline   Reply With Quote
Old 07-27-2009, 12:57 PM   #2
navyflyer72
Or would this one plug into the back of the head unit?
http://shop.sirius.com/edealinv/serv...9&oldParentID=
Old 07-27-2009, 01:11 PM   #3
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
The aux cable should work but since i dont have any of those i cant tell you for you sure. i'm guessing it would be like plugging in an ipod into the aux port.
Old 07-27-2009, 05:36 PM   #4
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
These appear to be like any other aux cable connection and not for the head unit connection.
Have you considered the Siletto Vehicle Kit? Unless the Siletto will get OK reception on its own you may need to consider how you provide an antenna as well as power - this kit may be a good solution though NOTE it doesn't come with the direct connection Aux cable.http://shop.sirius.com/edealinv/serv...0&oldParentID=
Here's a link to this product's manual in pdf form.http://www.sirius.com/pdf/manuals/St...tion-guide.pdf See Page 48 for the direct connection instructions.
While I don't have a Sitellto I installed my Starmate 4 using an antenna mounted on the back inside deck - gets great reception so you don't have to mount it outside. I use an Aux cable to connect the Aux port and get power from the power port in the cubby. As the connect is via the Aux you will not get station information on the head unit display. It doesn't appear that the Stiletto 2 has a USB or Bluetooth capability which may have worked with the headunit in a more integrated way.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 07-27-2009, 07:53 PM   #5
navyflyer72
Thanks for all the feedback, anyone know if I would need this "kit" that includes an adapter for GM vehicles, says there is some non-standard size ends so you need these adapetrs to convert from a smaller antenna connector to the standard motorola connector? Just wondering if I would actually need this or just the Sirius FMDA25? Thanks, by the way how did you mount your antenna in the rear deck and where is it located (center/rear I'm assuming)?
Thanks again. Gotta have my Howard and Bubba!
Does anyone have a picture of the back of the head unit? That may help...
Old 07-27-2009, 08:55 PM   #6
az5thgen
az5thgen's Avatar
Drives: 2010 1LT
Why don't you just go with XM and get "The best of Sirius" package which includes both of Howards channels? We did that and they gave us a big discount on the package. We have had 2 cars on Sirius for years.
That way there isn't any adapters or antennas involved.
az5thgen is offline   Reply With Quote
Old 07-27-2009, 09:01 PM   #7
5th Gen SS
5th Gen SS's Avatar
Drives: 2010 2SS/RS M6 IOM and Black/IOM
+1
5th Gen SS is offline   Reply With Quote
Old 07-28-2009, 01:11 AM   #8
2010CamaroOutlaw
Drives: CGM 2SS/RS
you should be able to just plug it into the ipod connector since it will read it as an aux input. It will sound a lot cleaner then going thru the stereo because you wont get any interference from the FM.
2010CamaroOutlaw is offline   Reply With Quote
Old 07-28-2009, 05:52 AM   #9
navyflyer72
OK, One more audio newby question: What if I got this:
http://www.crutchfield.com/p_607SIRG...iled_info#tabs
Could I remove the nasty, huge XM sharkfin and replace it with the small Sirius antenna running the antenna wire through the bolt holes for the XM antenna? Anyone know if this SIR-GM1 would work with our head units in the Camaro (MCOR)?
If not I am going to call XM and see about the best of Sirius, my issue is that I have already paid for a lifetime Sirius subscription (no payments again ever!) and if I call XM I am sure they will want me to buy and XM subscription PLUS the best of sirius package, you see my issue? If I can get good antenna reception from the rear speaker shelf and plug into my aux jack I should be pretty happy.
Thanks again for all the info.
Regards, George
Old 07-28-2009, 12:16 PM   #10
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
Regards, George
i am fairly sure that the shark fin is shaped the way it is because it has XM and onstar in it....i kinda like how it looks
levi1922 is offline   Reply With Quote
Old 08-05-2009, 05:05 AM   #11
Mikechop
Drives: 2LT, black
Regards, George
They will require you to buy a seperate XM subscription. I am in the same boat and went round and round with them. I told them I will not activate the radio. They really need to change their policies or they will be out of business sooner than they think.
Mikechop is offline   Reply With Quote
Sirius using shark fin aberg Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 03-23-2009 06:22 PM
What are my options for Sirius subscription? Sean_W Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 02-23-2009 06:53 PM
Concerning the Sirius XM and Liberty Media Agreement VJCamaro 5th Gen Camaro SS LS LT General Discussions 1 02-20-2009 07:38 PM
Sirius XM Radio drummerstevey Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 08-04-2008 09:12 PM
XM or Sirius? darthknight72 Off-topic Discussions 16 08-01-2007 06:36 PM
