Old 03-19-2014, 12:16 PM   #1
X-Factor
Chick Racer
X-Factor's Avatar
Drives: 2017 50th 2SS
Installed Rear ZL1 Sway Bar - Banjo Bolt hitting on V6 Stock Brakes
Hi Everyone,
I have a 2LT/RS Camaro, with stock V6 brakes. We just installed the rear ZL1/1LE sway bar last night on my ride. But now I'm having problems with the banjo bolt hitting and making my braking not so fun to say the least...
We are currently working on fixing this situation by putting new rear brake pads on. First of all hopefully this will fix it, but if not, does anyone have any suggestions? We did move the brake line a little bit, so i dont have any issues with that.
Thanks so much!
From a Pfadt Thread: The last thing in the world that you want is to make contact with a banjo bolt and either kink or break that brake line.
X-Factor is offline   Reply With Quote
Old 03-19-2014, 02:45 PM   #2
Sleepy
Sleepy's Avatar
Drives: 2011 LS M6 SW
Can you post a pic of it hitting along with the thickness of your pads? I am curious how far the pads will have to wear in order for this to happen. You can also change the rotors too if it is worn. That will give you a little more clearance but at that point, you might as well switch to Brembo.
Sleepy is offline   Reply With Quote
Old 03-19-2014, 02:52 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I have heard of some doing new pads and it gives you clearance for a while, but the only real fix is to upgrade to the SS calipers.
Best regards,
Tyler
888-308-6007
Old 03-19-2014, 03:05 PM   #4
intensifi
Drives: '12 2LT Convertible
Best regards,
Tyler
888-308-6007
Yes. those V6 calipers were huge.
but doesn't some of the clearance come from the fact that the Brembos are "taller" to accommodate the bigger rotor?
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 03-19-2014, 03:17 PM   #5
X-Factor
Chick Racer
X-Factor's Avatar
Will do, we will be working on my car later this afternoon, so i will take a picture and post.
Best regards,
Tyler
888-308-6007
Thanks Tyler... guess i better start saving up my mod money... lol Thank so much for yalls help. I'll let yall know the outcome tonight.
Old 03-19-2014, 09:53 PM   #6
X-Factor
Chick Racer
X-Factor's Avatar
Here are my pics, my undercarriage is filthy, was on a rock road in the county over the weekend.
Found my brake pads were at about 50%. And the bolt had been hitting the sway bar, decreasing my braking power forsure. So we changed out the pads, and shaved down the bolt a little. And my car stops like a champ now! Working on saving money for Brembos for the long haul though.....
Brake pads
Rear bolt touching sway bar
Partial shaved off bolt
Final Caliper and bolt clearance
Sent from my New and Improved Phablet!
Old 03-19-2014, 10:07 PM   #7
sycraft
COTW 5/06/2013
sycraft's Avatar
If you remember I told you that may happen, start saving for Brembo takeoffs.... as soon as the pads wear it will happen again. I will keep my eye out for you and some brembos.
Old 03-19-2014, 11:06 PM   #8
X-Factor
Chick Racer
X-Factor's Avatar
Thanks sycraft... you were right! But ill need to save for a little while.. lol
Old 03-20-2014, 02:48 AM   #9
humblebeast07
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF
Glad you got it working...how does it feel?
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
humblebeast07 is offline   Reply With Quote
Old 03-20-2014, 07:27 AM   #10
X-Factor
Chick Racer
X-Factor's Avatar
I only have the rear on right now, this weekend everything should be on... right now it feels like i have more control over my car... so i can't wait till the fronts are on! Autocross baby!
Old 03-20-2014, 03:19 PM   #11
Sleepy
Sleepy's Avatar
Thanks for the pictures. Here is an idea. If the brake pads are identical inside and outside, you can replace the outside pads only to push the calipers out and don't replace the half worn inside pads. When the new outside pads is half worn and inside pad is fully worn, you can move the half worn outside pad to the inside and use the remaining pair of new pads on the outside. That way you don't have to keep buying pads.
Old 03-20-2014, 09:53 PM   #12
X-Factor
Chick Racer
X-Factor's Avatar
Oh no problem at all. Not too many folks had mentioned having problems like this, and I know there are quite a few of us V6's that have this set up with stock brakes. But that sounds like a great idea, thanks!
Old 03-20-2014, 10:28 PM   #13
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
How many miles on the brakes? Ours was no where close when we had our v6 brakes on the car
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 03-20-2014, 10:30 PM   #14
ICTsccaCamaro
ITCRNRS
Oh i see the issue you have lowering springs correct? This changes the angle of the rear sway bar causing the interference.
