Old 03-21-2014, 02:54 PM   #1
SIM2LS13
SIM2LS13's Avatar
Drives: 2013 2LS SIM
Catch can question
Just a quick question for everyone..... Yesterday I had my first oil change, got it done at the dealer. When I got home I opened the hood while the engine was idling and I heard a loud hissing noise that sounded like it was coming from the catch can. I was able to make the sound stop by squeezing the hose coming into the catch can. Is this a normal sound? I've never heard it while the hood was closed.
  • MRR M228 wheels
  • 20x10 Nitto Invo 275/40
  • 20x11 Nitto Invo 315/35
  • Apex 1.25" Drop Springs
  • Cold Air Inductions intake
  • Elite Engineering catch can
  • MRT v2 exhaust
  • Four pack gauges
  • OEM ZL1 front bumper
  • OEM ZL1 side rockers
  • OEM ZL1 rear diffuser
  • OEM ZL1 grille
SIM2LS13 is offline   Reply With Quote
Old 03-21-2014, 03:14 PM   #2
Ehmsea
Ehmsea's Avatar
Drives: 2013 2SS RS Hurst NPP
sounds like the drain valve is open. turn the wing nut to close the valve, should be good to go...
No Worries
CAI Intake w/washer relocation and race scoop
Ported Throttle Body (Polished)
Kooks LT stepped headers 1-3/4 to 1-7/8
High Flow Cats
Livernois Motorsports Stage 2c Cam Package
https://www.youtube.com/watch?v=AKXyCyBh9BU
Hill Start Assist Delete
Ehmsea is offline   Reply With Quote
Old 03-21-2014, 04:54 PM   #3
Zig Zag
Drives: 2014 1LT
The OP has an Elite catch can, no drain valve.
From what I've read here on the forum the hissing sound is normal.
Maybe someone with some more experience will chime in....
Zig Zag is offline   Reply With Quote
Old 03-21-2014, 05:19 PM   #4
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
Do you have hose clamps on both sides of 3/8" fuel lines you're running to it? You should hear a little hissing with the softer fuel line. Unless you throw a cell you're probably okay. Make sure everything is secured nice and tightly. Tight is right.
6bangerBOOM is offline   Reply With Quote
Old 03-21-2014, 05:37 PM   #5
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
Fuel lines?
RobertRS is offline   Reply With Quote
Old 03-21-2014, 06:37 PM   #6
skibik
Guest
Drives: bbbbbb
I thought mine had a problem also. It sounds like a very bad vacuum leak. Contacted Elite and they replied back asking if my hoses were routed according to the picture or link they sent. I did respond with a yes but they never got back to me after that reply. I am gathering that it is just the volume of air being sucked through the engine and PCV system by the hose connected to the airbox on the clean side. Just my thought anyway.
Dean.
skibik is offline   Reply With Quote
Old 03-21-2014, 07:01 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Did you use Teflon tape on the threads of the fittings? Are your clamps in place and secure?
Some sound is normal, but if you said no to either of the above questions, that is likely your answer.
Best regards,
Tyler
888-308-6007
Old 03-21-2014, 07:19 PM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Catch can question
A slight hissing sound is normal, no worries.
It's just the airflow through the rubber hoses.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 03-21-2014, 07:34 PM   #9
6bangerBOOM
Drives: 2016 1SS SW
Originally Posted by RobertRS View Post
Fuel lines?
Yeah, most catch can installs require the use of 3/8" hose, which is usually used for fuel. My bad on the wording that's just what I personally refer to the stuff as!
Old 03-21-2014, 08:07 PM   #10
RobertRS
RobertRS's Avatar
10-4 ...No big woop. Life is good.
Old 03-22-2014, 02:42 PM   #11
SIM2LS13
SIM2LS13's Avatar
Best regards,
Tyler
888-308-6007
Yea I used Teflon tape on the threads, and the clamps are secure. I guess the sound is normal, I just never really had the hood open while the engine was running to hear it before the other day. Thanks for the replies everyone.
  • MRR M228 wheels
  • MRT v2 exhaust
  • Four pack gauges
  • OEM ZL1 grille
Old 03-24-2014, 01:29 PM   #12
8863
Drives: 2013 Camaro 2LT RS
I'm leaning toward the purchase of a catch can for my 2013 Camaro's LFX engine. I will probably buy one from Elite Engineering. However, the hissing sound that some folks speak of on this forum after installing a catch can gives me some concern. Can the hissing sound be heard with the hood closed? Can it be heard in the passenger compartment? Since many different posts have popped up over the last several months about the hissing sound, has Elite Engineering come up with a design that would eliminate the hiss?
8863 is offline   Reply With Quote
Old 03-24-2014, 03:03 PM   #13
SIM2LS13
SIM2LS13's Avatar
I have never heard the hiss from inside the passenger compartment. I only heard it when I opened the hood while the engine was running.
  • MRR M228 wheels
  • MRT v2 exhaust
  • Four pack gauges
  • OEM ZL1 grille
Old 03-24-2014, 03:24 PM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
Catch can question
All catch cans hiss, it's from the hoses. And no, you cannot hear it inside the cabin. In fact as the above poster stated you can only hear it with the hood up.
FSP tuned: 377/389
