Old 03-30-2014, 02:54 AM   #1
MosesBarkley
MosesBarkley's Avatar
Drives: 2014 Camaro RS/2SS 1LE
Weird Thing Happened to Audio/Nav System
Something weird happened while just driving along... The audio/navigation system just went completely black. It was working fine one minute and just completely went black the next minute and would not come back on. I was on my way to a grocery store, so I shut the car off when I got there and waited about 3 or minutes and started it again. The audio/nav system was still out, so I called my dealership as I was walking into the store. They said they'd never heard of this happening, so I made an appointment to take it in the next day. After about 30 minutes in the store, I returned to my car and started it up and the audio/nav system was working again.
Anyone else had this happen?
MosesBarkley is offline   Reply With Quote
Old 03-30-2014, 07:15 AM   #2
Cooley
Cooley's Avatar
Drives: 2013 2SS 1LE
I had that happen while I was at the dealership once. The service manager did a disconnect;waited 30 seconds, and reconnected the battery and the radio started working again. I was then told it is because the amp will sometimes get hot and cause this problem.
Cooley is offline   Reply With Quote
Old 03-30-2014, 06:19 PM   #3
esco214
esco214's Avatar
Drives: 2014 2SS/RS Camaro 1LE
I was driving and started to get a little hot, went to turn my air condition on, and to my surprise nothing was working. Heated seat, would not work as well. My audio and nav was working but any of the controls that function the air or heater did not work. When I arrived home, and I shut it off and waited and turned it back on and still did not work. I called made an apt, and put the car up for the night, to my surprise it started fine the next morning. The dealership said they could not troubleshoot it cause it was working fine. It has not happened since, so just keep an eye for it. Hopefully it was just a glitch and you wont have no serious problems, but its under warranty anyways. Good luck.
esco214 is offline   Reply With Quote
Old 03-30-2014, 07:16 PM   #4
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Happened to me and dealership allegedly did a software update, still happened to me 2 more times after the update. Its been 5 months and so far no more problems.
Sapper12b is offline   Reply With Quote
Old 03-30-2014, 08:27 PM   #5
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Never had a problem with mine. I'm at 4600 miles.
Old 04-07-2014, 02:07 AM   #6
MosesBarkley
Audio system also "freezes" up a lot when connected to my iPhone... Happens regardless of whether listening to music through Bluetooth or when connected via USB port. I get the message, "Audio Paused". After a minute or so, it'll start playing again; other times, I have to manually press "Play".
Really annoyed with audio/navigation system issues!
Old 04-07-2014, 06:58 AM   #7
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
I have same Issue system will lock up nothing on radio works. I press and hold power button and it resets to the startup screen and comes back on. Maybe a little to much going on for what ever tiny processor the put in it.
trashmanssd is offline   Reply With Quote
Old 04-07-2014, 11:02 PM   #8
T-Rob
Drives: 2014 Camaro 2SS 1LE
Same exact issues on mine with my iPod or anything using the USB port. Have had it in twice for"software" upgrades.
T-Rob is offline   Reply With Quote
Old 04-08-2014, 12:11 AM   #9
SS MPSTR
Resident Artichoke
SS MPSTR's Avatar
Drives: 14 1LE, 97 Z28, 07 Z06, 67 Chev SS
Just happened to me today. I was playing tunes from my iPhone through bluetooth and the fan/AC would not come on. After a minute or so, it finally kicked on. Weird.
2014 Camaro SS 1LE, 2016 Z06 Corvette, 1997 Camaro Z28, 1967 Chevelle SS
SS MPSTR is offline   Reply With Quote
Old 04-08-2014, 11:05 AM   #10
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
Sounds like an overheating issue. GM will have to look into that! With all the electronics running, a LOT of heat is generated and if tightly packed in the dash without any air circulation, they are going to have overheating problems.
Kendall421 is offline   Reply With Quote
Old 04-08-2014, 11:06 AM   #11
HollyVenus
The girl with the 2 Danes
HollyVenus's Avatar
Drives: 2014 2SS/RS LS3
mind did this the other day... I took a photo..
also had issues with the comfort dials.. I am turn the air up and it shows off on the display... :inono:
HollyVenus is offline   Reply With Quote
Old 04-08-2014, 11:07 AM   #12
mcynet
mcynet's Avatar
Drives: 2016 Camaro 2SS
I had it happen once after I had it cranked for 15 min. I think the amp gets hot.
Drives,
2016 Camaro 2 SS,
(OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging
mcynet is offline   Reply With Quote
Old 04-08-2014, 12:08 PM   #13
Cool1LE
Cool1LE's Avatar
Drives: 2014 Blk 2SS/1LE
Once in awhile the radio will go to AUX without me touching anything. After a few seconds it bounces back and forth then its fine
Cool1LE is offline   Reply With Quote
Old 04-09-2014, 07:20 AM   #14
TonyRomo82
TonyRomo82's Avatar
Drives: 2014 Summit White 2SS Camaro 1LE/RS
Couple of days ago I tried to turn on my AC but nothing would happen, it would just display at 0. After trying about 8 times it finally kicked in. Couple hours later I was driving home and it decided to turn my volume from 16 to 24 by it self. Just got back from a furneral, wonder if my Grandmother is messing with me.
TonyRomo82 is offline   Reply With Quote
