04-14-2014, 03:34 AM | #1 |
Tire question
Will a 305 tire got on the factory back SS wheels? Need help ASAP!
04-14-2014, 02:30 PM | #2 |
Fit**
04-14-2014, 03:10 PM | #3 |
yes a 305 will fit
305/35/20 is what you will need to run to make it fit right overall diameter is 28.4" the stock 275/40/20 is 28.7" So you would be fine. |
04-14-2014, 04:33 PM | #4 |
Thanks! Very much appreciated!
04-14-2014, 05:13 PM | #5 |
04-14-2014, 05:18 PM | #6 |
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
So with that on the rear, what would I have to run on the front stock rim to keep the ride height relatively close to factory setting? Going as wide as possible.
04-14-2014, 07:51 PM | #7 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
for a stock front wheel.......the largest I would go would be 265/40-20. but if you want....get another pair of rear wheels and run 275/40's
04-14-2014, 08:08 PM | #8 |
04-15-2014, 07:56 AM | #9 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
Tire size
If a 265/40 is ok to run on a stock 8 inch rim, can a 275/40 be run safely on a 8.5 inch front rim?
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
04-15-2014, 02:05 PM | #10 |
04-16-2014, 03:30 PM | #11 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
It will work but officially you would want a 9 inch rim to run a 275 according to the tire rim width range.
