04-17-2014, 12:56 PM | #1 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Road course, 18" wheels?
Hello All,
I am wondering if any ZL1 users are running 18" wheels for a car they use on a road course? If so what brand, size and offset? I just installed the CTS-V front brake set-up on my 1LE and want to see what options there are for 18" wheels Thank you, Matt
04-17-2014, 10:48 PM | #2 |
Matt, give John at CCW a call 1.386.258.0083.
When i talked to him last year he assured me the Zl1 brakes fit under his 18 inch wheels |
04-18-2014, 08:09 AM | #3 |
Thanks!.....I saw you car getting a little work last week at Rodgers
04-18-2014, 04:50 PM | #4 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Make sure you share any information you get on here.
04-22-2014, 01:54 PM | #5 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I'm the 19" TSW Interlagos for road racing. They work very well, you could get the 18's on there but I suspect the extra air space helps with brake heat.... would have to do some extensive tests to prove it though.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
04-22-2014, 07:27 PM | #6 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
TSW Interlagos in 18x9.5". Then you can run Continental Sport Cups on all 4 corners in 275/35/18 size. The Interlagos cost under $1,000 a set from Discount Tire Direct and the Conti scrubs are under $500 a set delivered. Doesn't hurt that the Interlagos are 19.9lbs apiece either.
04-22-2014, 10:33 PM | #7 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
07-28-2014, 01:35 PM | #8 |
Romans10:9-13
Bumo for more info
OK, so anyone running 18's?
what offset? what width? I really would rather do 18's. The tires are cheaper than 19's. I am looking into forgestar 18's. They do 10, 11, & 12 inches wide. I am looking at doing a square set up so I can rotate front to rear
07-28-2014, 02:12 PM | #9 |
Drives: Widebody 2013 Mustang GT Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
If you've got ZL1 brakes, no worries, if you've got CTS-V brakes, no worries, we can make it work for the Forgestar F14's which you can see pictures below on a ZL1 in 18x10 and 18x11, OR you can go with the CF5's as well which have great brake clearance:
Hope that helps! |
07-28-2014, 02:31 PM | #10 | |
Romans10:9-13
It answers some questions. The one I am still not sure what to use is the offsets. I am not a big fan of the F14's
07-28-2014, 02:35 PM | #11 | |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
07-28-2014, 03:32 PM | #12 | |
Forgestar picks the offsets for you, OR you can pick yourself, totally up to you. If you're an offset guru and you really want the exact fitment that you've seen on another car, then you can pick, otherwise just let me know what you're using it for, what mods you have on the car, that might change offset and sizing, and then we're done. We try to make it easy for you guys I agree! |
07-28-2014, 03:46 PM | #13 | |
Speed Freak
Edit I found it post number 3. http://www.camaro5.com/forums/showthread.php?t=343402
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. Last edited by jessrayo; 07-28-2014 at 03:57 PM. |
07-31-2014, 07:16 AM | #14 |
I had a set of aftermarket 20 x 10, ET25 wheels that could be rotated....unfortunately you would give up the 1" in the rear and they were sold.
I ended up buying a set of 19" Z/28 wheels (19 x 11" and 19 x11.5") and some 305/30/19 Hankook RS3s. (No you still cant order them, no I cant get anymore. Yes, it pays to live in the Detroit area!) -Matt
