![]() Drives: ZL1 Convertible Join Date: Aug 2012
ZL1 Stock Tires - How many miles
Hi,
I have a few questions about the stock tires on our ZL1(s)
Thanks! |
Camaro fan since birth
I have 7000 miles on mine, and the tires have a lot of life left in them. In one of the grooves you should see a small notch which is the wear indicator. The notch in the groove is the same height as when you should replace your tires.
http://www.thetirechoice.com/learnin...pth-tests.aspx Sent from my SAMSUNG-SGH-I337 using Tapatalk
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
2. There have to be wear bars in the tread that, when you're worn down to them appear as solid rubber strips across the various tread grooves.
1. It's heavily dependent on your driving and on how well your car's alignment and inflation pressures suit that specific driving. Some people barely get 5000 miles per 100 rated treadwear. Other folks can get 10,000 or more per 100. I can usually get 12,000/100 or a bit more on any car with any tires and I don't drive gently (but I don't drag race or do burnouts, which are huge influences). Norm |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
I have 17,000 miles on my original tires and they are done. The rears are worse than the fronts (as they should be!). That includes some autoX at the past 2 Camaro5Fests and probably 15 drag strip runs with light burnouts.
The rears don't grip anymore and the tread is almost down to the wear bars. The fronts probably could go a little longer, but I will swap the set. The new ones will be installed before my drive to Camaro5Fest. I picked up a lightly used (1,000 miles) set of tires off a 1LE and will be running a square setup. I got such a good deal I couldn't pass it up! |
Summit White 2012 ZL1 M6
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9 Join Date: Jul 2008
12,500 and need replacing
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
11,000...some life but not great
#7 | |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
About the same here. I have about 18 k and the fronts are almost to the wear bars. The rears were done around 16k and I had bought two rears from a friend about a year ago for $150 and I had put them on back in December. Now those are about the same as front. I have had to daily drive my car since November so I drive a little more aggressive. Just can't help it, I just love this car.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black ZL1 Join Date: Apr 2013
First, check your wear markers.
Second, depends on what you do with your car. I don't really do any HPDE or AutoX, so I probably didn't wear mine as fast as some. I launched on a dag strip about 100 times on the original set. So the rears were pretty well gone when the fronts still had some life. I got 22,500, but I probably went just a little long. Maybe closer to 21k would have been better.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
#9 |
![]() Drives: 13 F150 Eco 14 ZL1 650 RWHP Join Date: Sep 2013
10k and done
#10 |
![]() Drives: 2000 Camaro SS 2013 ZL1 Camaro Join Date: Jul 2012
8000k and mine are done. Not a daily driver (meaning I really test the tires every drive)
#11 |
![]() Drives: Camaro ZL1 Join Date: May 2012
11k and they were slicks. I kept very close attention to the PSI, but daily drive like i am in a police chase, meaning i spun the back tires at least 2 or 3 times a day, plus quite a few trips to the drag strip.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
#12 |
![]() Drives: '13 ZL1 CRT #702; '05 Hemi Ram Join Date: Oct 2012
I just replaced the brake pads today with the Hawk performance ceramic pads, and I saw the back tires are almost down to the wear bars. I'm just under 10000 miles. The fronts still have plenty of life left. I don't track it, but I drive fairly aggressively. Planning on replacing the Goodyear tires with the Michelin Pilot Super Sports.
#13 |
![]() Drives: 2013 ZL1 Join Date: Nov 2012
15k on the stocks and they are bald. They were probably done at 13k but i still have them on. I DD with them and have made 10 passes at the strip. They slide and skid a little, but at least it makes me keep my foot out of it!
1974 Cadillac Coupe DeVille
2002 Camaro Z28 A4 | 10.80 @ 131 | 383ci, D1SC, 4L80E, 9" 2013 Camaro ZL1 A6 | 12.62 @ 113 | Stock *SOLD ![]() 2017 Lexus GS350F |
#14 |
COMPULSIVE CAMARO OWNER
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67 Join Date: Nov 2009
11k and they are done. New ones before c5fest5
