Old 05-09-2014, 10:17 PM   #1
orangeonblackss2
Drives: orange ss with black wheeels
Throttle bodie flap
have anyone removed the flap that's inside the throttle bodie if so did it make any diff.
orangeonblackss2 is offline   Reply With Quote
Old 05-09-2014, 10:31 PM   #2
Bo White
Bo White's Avatar
Flap? Are you asking about the brass blade?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-09-2014, 10:53 PM   #3
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
I hope not
Saint Alban is offline   Reply With Quote
Old 05-09-2014, 11:02 PM   #4
rich3fan
What's this button do?
rich3fan's Avatar
Drives: 2019 Black 2SS
This thread = epic fail!
2019 Black & Red & Silver 2SS - Bone Stock
rich3fan is offline   Reply With Quote
Old 05-09-2014, 11:09 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What flap are you talking about?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-09-2014, 11:13 PM   #6
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Da fook ?
Not a good idea since the engine would go right to the rev limiter on start up.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 05-09-2014, 11:29 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I suppose that would improve flow!
Not sure if serious, but I highly recommend not doing that.
Rhino79 is offline   Reply With Quote
Old 05-09-2014, 11:45 PM   #8
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Throttle bodie flap
Originally Posted by 14pilot View Post
Da fook ?
Lol. Nvm. I misread. Removed, not moved.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 05-10-2014, 12:58 AM   #9
Saint Alban
100% airflow increase. Why didn't I think of this?!
Old 05-10-2014, 09:10 AM   #10
orangeonblackss2
on the inside of the throttle bodie there is a blade/flap whatever.. it has two bolts holding it... it control the amount of air the car is getting more you push the gas more air it lets thru... I was thinking if you removed you would get more air flow.. im going to my tuner today im going to remove mine and see if it works I drag race
bikes and we did this mod to help with air flow.... if you take your cold air off and look in the throttle bodie you can see it plain as day...
Old 05-10-2014, 09:15 AM   #11
orangeonblackss2
Da fook ?
why would the engine to wide open throttle?
Old 05-10-2014, 09:41 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
we have a wireless throttle connection meaning the car senses the position of the go pedal and opens the throttle blade appropriately in response to the movement of the pedal with out a wire as in old style linkage for a cars carburation or fuel injection. Removing the throttle blade would be very stupid as this is not some crappy motorcycle and likely would cause the car to fall flat on its face and stall from having too much air to fuel when its cold, let alone when your just part throttle driving, more is not always better, educate yourself....... that's why they made springs on the side of manifolds that slowly heated up on the intake to allow slowly more air to get into a cars engine...its called a choke...automatic choke , some had electric chokes on the carburetor, some had a choke lever you pulled until the car would start then slowly pushed in over time as the car kept running....... also there were primaries ands secondary lets with two divided sections in a performance cars four barrel carburetor and only part of the "butterflys" the primary would open partially and correspond with the movement of the gas pedal via mechanical linkage to the carburetor......... The butterfly valve as it is commonly known is what you are referring to as the "flap" on our throttle body. And removing the flap thingy would just flood the car with too much air and the dumbo on the pedal would have to press the pedal harder to supply more fuel to keep it going which in turn would electronically turn a little shaft that used to hold the flap and do nothing but tell the car to give it more gas...... Or a chuckle head could try and drive it that way, I would love to watch....ROFL I imagine it would be great on U tube, might even get some money on Americas dumbest backyard mechanics or something. The engine I do not think would go to wide open throttle unless the guy with the go pedal was pushing that hard to keep it running unless the engine could sense the air flow and responds through flowing more gasoline like say if the engine had some kind of fancy thing called a sensor....... that could mean unless someone turned the car off while running like at WOT or stuck their hand over the intake opening to choke it someone could what....almost blow up their engine repeatedly bouncing off the rev limiter..... maybe set it on fire if done long enough.... or finish first in Americas dumbest hillbilly mechanics competition.............. lol god you have me laughing......... If you do not see what I saying here its a bad idea, but be sure and keep us posted..................rofl
Old 05-10-2014, 09:50 AM   #13
hush
Drives: 2013 Camaro SSRS L99
Send a message via Skype™ to hush
It has to be a joke...
hush is offline   Reply With Quote
Old 05-10-2014, 10:05 AM   #14
That_Guy
That_Guy's Avatar
Drives: n/a
On a bike you remove the secondary butterflies, the electronic ones before the butterflies contoured by the throttle cable. Please don't remove the throttle body blade on your car.
That_Guy is offline   Reply With Quote
