What's this button do?
Drives: 2019 Black 2SS Join Date: Apr 2013
Fluidampr vs Powerbond UD Ballancer
First, when you shop for a Powerbond pulley, you're sent to slponline's site. Is Powerbond owned by SLP?
I like the theory behind Fluidampr's harmonic balancer, but it cost +$100 more than Powerbond's UDP. Would the casual weekend racer with no immediate plans for a cam need something like Fluidampr's offering?
2019 Black & Red & Silver 2SS - Bone Stock
I'm your huckleberry...
Drives: '10 2SS/RS, '88 IROC vert Join Date: Sep 2010
Been wondering the same...
'88 IROC-Z vert (14.9 @ 92.3) //
'10 2SS/RS LS3 - 423 RWHP, 418 RWTQ |
#3 | |
![]() Drives: 1969, 70, 2010, and 2012 Camaros Join Date: Mar 2014
#4 | |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
ATI?
![]() Hmmm... more investigation needed.
#6 |
ATI is a rubber damper however it has multiple rubber rings to help control different orders of vibration. The OEM damper has one rubber ring to help control the worst order of harmonics for the entire RPM range. A Fluidampr is frequency insensitive because of the inertia ring shearing through the viscous fluid, meaning it will control all orders of vibration for the entire RPM range.
#7 | |
#8 | |
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra Join Date: Nov 2009
#9 | |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
Saw this thread and search online and scored a new Fluidampr 760121 got $239 to my door. Buyer bought for a GM Crate LS3 but has Corvette accessories so it would not fit and couldnt return it as it was over 30 days
#11 |
ATI is a bigger company as they can do more advertising however Fluidampr only designs and builds viscous dampers for the OEM and aftermarket so they are 100% focused on damper technology. ATI has a good product however they also offer a lot of other products. The Fluidampr housing is steel however the pulley is aluminum to help with some of the rotating mass. Dampers are heavy for a reason otherwise they won't be able to control torsional vibration. Fluidampr is the best damper investment you can make for your engine.
#12 |
I've been told that Fluidampr and ATI ballancers will need to be rebuilt at some point in their lifetime, and I assume when this occurs is dependent on the application. I'm wondering what component or components wear out or degrade that necessitates this?
#13 | |
Fluidampr has no rubber component and the viscous fluid will not deteriorate or weaken over time or use for as long as you have your engine. Therefore there is no reason to rebuild them. |
