Old 06-27-2014, 02:44 PM   #1
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2016 Camaro 1SS
Does the CAI scoop really help?
Looking for people who have added the Apex Motorsports CAI Scoop really help on the V6 model? Is it a noticeable performance increase?
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning
GAHDOOSH is offline   Reply With Quote
Old 06-27-2014, 03:24 PM   #2
Desertion
Drives: 2010 1LT/RS Transformer Edition
+1
Desertion is offline   Reply With Quote
Old 06-27-2014, 03:38 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I added it to my K&N Typhoon intake. It made quite a noticeable difference... well, noticeable enough to feel a power difference and keep the air filter / air box area significantly cooler to the touch.
DSX_Camaro is offline   Reply With Quote
Old 06-27-2014, 03:59 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Would this help on the track as well?
Mods:
Old 06-27-2014, 04:19 PM   #5
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I noticed an improvement in throttle response when I added mine. It will benefit the car any time it is moving forward, so yes it will help on the track.
kjkjr27 is offline   Reply With Quote
Old 06-28-2014, 09:35 AM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Yes I thought it helped too. As long as you have a aftermarket cai with an open bottom. The CAI brand is perfect, but even if you've got a Airaid- just lose the stock scoop and open the bottom and side by the fender with a couple of 2" holes (at least that's what I did!).
The scoop will direct some fresh air where your motor needs it the most. I felt a nice improvement in throttle response. The Apex kit is well designed and you retain 2quarts of washer fluid capacity (down from the 1gallon stock).
Old 06-28-2014, 10:46 AM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Don't expect it to be like a supercharger but you definitely will notice an improvement. It directs a much greater quantity of fresh air into the intake than the stock funnel ever could. You will notice improved throttle response in general and when you get hard on the throttle you will feel more power, especially above 3000 RPM.
Whoosh!
Old 06-28-2014, 12:49 PM   #8
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Sweet, the butt dyno is the most important dyno (to me anyways)
Thanks guys!
Does moving the washer bottle kit help with performance as well or is that just for convenience?
GAHDOOSH
Old 06-28-2014, 12:56 PM   #9
Apex Motorsports
Thanks guys!
The scoop occupies the same space as the stock washer fluid tank. It has to be removed when you install the scoop. That is what the replacement tank is for.
Old 06-28-2014, 06:13 PM   #10
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Ahhhh.... that makes a lot of sense. Thanks for clearing that up.
GAHDOOSH
Old 06-28-2014, 08:16 PM   #11
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Gonna have a scoop for sale if you are interested
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 07-01-2014, 10:04 AM   #12
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Sure, how much?
I don't have the washer fluid relocation kit so I will have to oder that
GAHDOOSH
Old 07-01-2014, 10:41 AM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Will this scoop and water relocation kit be compatible with the IPF S/C kit?
I know I'll loose the CAI box and intake tube and filter but will the scoop still work for the IPF intake?
Mods:
Old 07-01-2014, 11:56 AM   #14
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
I have the Roto-Fab CAI, Roto-Fab Windshield Washer Relocation Kit, and the ADM Ram Air Scoop in my 2010 Camaro 2LT/RS and once I installed the final part (the ADM Ram Air Scoop) the sound improved and Butt Dyno really went up. The only thing I have left to do is install a set of DT Shortie Headers on my car.
Walt
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
