Jason 98 TA
Old 07-02-2014, 08:47 AM   #1
mrshanes
Drives: 2014 Camaro ZL1
"How much horsepower?"
Hi all. First post here. I've been lurking for a while though. I picked up my ZL1 a couple months ago and since then I've been approached a couple times and people ask "How much horsepower?" What is your response? Mine is still stock and all the marketing says 580. We all know that's at the crank and there is less than that at the wheels, but that's really what counts. Especially for you folks who are modified... do you quote the marketing numbers or try to explain the difference in crank vs rwhp? Just curious how everyone answers this question.
mrshanes is offline   Reply With Quote
Old 07-02-2014, 09:03 AM   #2
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
I tell them it's stock, and tell them 580 at the crank. Most people that have asked me that aren't car people, and usually follow up with "What type gas mileage do you get?!?" or "Where can you us that kind of power around here?!?!"
Anybody that is a car fan will more than likely already know about the ZL1 and what the specifications are. At least that's my experience.
--- DarthZL1 - 2014 ZL1 #2095 M6 Black. Bone Stock ---
--- BigNLo - 1996 Impala SS Hot Rod Black. Lots of mods ---
DarthZL1 is offline   Reply With Quote
Old 07-02-2014, 09:05 AM   #3
BigBoyBlue
Go NY Giants & NY Rangers
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
Cars are marketed at their crank horsepower. Most people don't understand the difference so I just say 580hp. If they ask "at the wheels or at the crank?", I will answer them. Otherwise it makes no sense to short change the ZL1. You have to compare apples with apples.
Welcome.
Molon Labe!
BigBoyBlue is offline   Reply With Quote
Old 07-02-2014, 09:10 AM   #4
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Just tell them the gross numbers. Unless they are a gearhead they're not going to understand the explanation anyway.
The average rwhp for a stock M6 is ~495. A6 is ~465.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 07-02-2014, 09:20 AM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
I just tell'm 580 stock HP......
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 07-02-2014, 10:57 AM   #6
BPG
Faster than you...
BPG's Avatar
Drives: 1194whp. 8.62@168. daily driver...
I tell them "not enough".
GTR
BPG is offline   Reply With Quote
Old 07-02-2014, 12:41 PM   #7
z28man2
z28man2's Avatar
Drives: 2013 Camaro ZL1 Coupe IOM
If you really want to get in some technical hp numbers, rule of thumb, manual loses 15% to driveline & auto 20%
so 580hp @ crank to wheels = 492 rwhp
580hp @ crank to wheels = 464 rwhp
again just a rule of thumb & my input
2013 Camaro ZL-1 #3553, IOM, Roto-Fab Intake, Vmax Ported TB, Apex Catch Can
z28man2 is offline   Reply With Quote
Old 07-02-2014, 02:25 PM   #8
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
I say more then most Mustangs out there lol!!!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 07-02-2014, 08:33 PM   #9
WSSICK
Drives: 2014 Red Hot ZL1
When asked I reply that it is stock and is rated at 580 brake horse power.
2014 Red Hot Camaro ZL1
2002 Victory Red Trans Am WS6
2000 Lt Pewter Metallic Silverado Z71
1996 Metallic Gray Ford Taurus GL
WSSICK is offline   Reply With Quote
Old 07-02-2014, 09:22 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I usually say 835 and counting. Then I have to explain I have about 6 dyno sheets that get higher everytime I change something on the car. My favorite is when I run a 10 second drag pass and then pull into the pit area to give it some cooldown time and someone comes up and asks if it is stock.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 07-02-2014, 09:27 PM   #11
hotlap
hotlap's Avatar
Drives: 18 Hot Wheels 2SS M6
I hope you reply YES.
Production Number 1755
hotlap is online now   Reply With Quote
Old 07-02-2014, 09:49 PM   #12
jessrayo
Speed Freak
jessrayo's Avatar
I usually give a long pause and then say I have a few upgrades on it....new air filter and that sort of thing...
Old 07-02-2014, 10:03 PM   #13
135Hoser
Drives: A bunch
I just switched to AMSOIL and now I'm running 10's!
135Hoser is offline   Reply With Quote
Old 07-03-2014, 01:21 AM   #14
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Usually I say around 600. I've only installed a CAI but if a guy with a Mustang or Challenger asks I say just under a 1,000 and watch their mouths drop open. Hahahahahaha!
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
