Old 07-20-2014, 10:40 PM   #1
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
Microfiber cloths, expensive isn't necessarily better.
I have been using these microfiber towels to quick detail my ZL1 (it's black, using Adam's quick detailer):
Autogeeks Microfiber Chinchilla buffing cloths
Griots Garage Speed Shine Micro Fiber Cloths
"Crappy" Autozone microfiber cloths.
I generally have been using the Autozone ones sparingly, or under the hood, or for the rims (I separate those, they become RIM ONLY rags). AND been using the Chinchilla and Griots as quick detailing rags.
I'll be the first to admit I'm really somewhat of a newb with this kind of thing... or at least in the past didn't care as much. So, maybe I was using the wrong rags, but when I would use the Chinchilla or Griots to dry after a wet wipe down with Adams, they would leave fibers behind that might as well have been glued to the car. Initially I thought that these were small very very frequent scratches in the clear coat, and I had screwed something up. I first started to notice (at least) after I had used Griot's waterless wash. So, initially I blamed it on that. NOW, I was seeing it after I do a quick detail. I determined it was fibers from the cloths. And they were a bitch to get off. And never would completely come off the trunk or hood.
Well, I just out of desperation used the Autozone microfiber cloths to dry after a quick detail (using the fancy ones for the wet wipe down) and not only did it not leave any fibers on the paint, it removed all the OLD ones that I just couldn't get up. AND after close inspection didn't leave any clear coat scratches. So... yay!!!
TL;DR: Fancy microfibers left debris that was impossible to get off. Autozone "crappy" microfibers picked all that stuff up and car looks great. Yay cheap!
--- DarthZL1 - 2014 ZL1 #2095 M6 Black. Bone Stock ---
--- BigNLo - 1996 Impala SS Hot Rod Black. Lots of mods ---
DarthZL1 is offline   Reply With Quote
Old 07-20-2014, 10:49 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You didn't mention any fancy or good microfiber in this whole rant.
In addition, it sounds like you didn't wash your 'fancy' ones first. Microfiber always needs to be washed first.
The scratches you were worried about from the 'fancy' ones? Don't worry, your autozone ones actually will leave those.
[B]
Old 07-20-2014, 10:49 PM   #3
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
Fancy in this case meant expensive.
They had been washed multiple times. Well... at least twice for both expensive ones.
Old 07-20-2014, 10:54 PM   #4
CamaroDreams07
Drives: Slow V6
Try these if you want actual quality microfiber. There are other good options, but these are the best.
http://www.carpro-us.com/microfiber-...-pile-16-x-16/
[B]
Old 07-20-2014, 11:02 PM   #5
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
$$$ Ouch.
Well, I'll give 'em a shot. Right now I'm just happy I no longer have a ZL1 that looks like it's shedding!
Old 07-20-2014, 11:15 PM   #6
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
There's a lot more than just checking to see if a scratch was left. There are different types of microfiber for different purposes, nap lengths, GPM, etc.
By the way, 10 times out of 10, expensive typically means better.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 07-20-2014, 11:21 PM   #7
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Just to chime in, I hear a lot of guys recommending http://www.theragcompany.com/
I just spend $40 there, going to try them out.
SPARTAN sui is offline   Reply With Quote
Old 07-21-2014, 08:29 AM   #8
Six.Two SC
Drives: 2018 Summit White Camaro 1SS
All MF towels lint, but some are way worse than others. A very good towel for overall use(quick detailing to polish removal) are these....
http://www.carpro-us.com/16-x-16-car...-towel-5-pack/
'18 Satin White Vinyl Wrapped 1SS, 6MT, Low Gloss Black Wheels, NPP Dual Mode Exhaust
Added: Diode Dynamics Black LED Sidemarkers, GM Dark Finish Tailights, GM ZL1 Black 3rd Brake Light, Black Plastidipped Bowties(front/rear), AFE Dry Drop In Filter, 12mm Spacers(front/rear)
Six.Two SC is offline   Reply With Quote
Old 07-21-2014, 10:59 AM   #9
CamaroDreams07
Drives: Slow V6
I like the Boa a lot for a low price towel.
[B]
Old 07-21-2014, 11:58 AM   #10
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Never had any problem with my CG MF towels, just a couple thought, do you wash your MF towels separate from any non MF fabric, maybe your car could use a good clay baring to remove any harsh contanmates from your paint? JMO
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 07-21-2014, 12:20 PM   #11
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
All good opinions. I do wash my microfibers together, EXCEPT for the Griot and Chinchilla ones, they are washed on their own (I have a mish mash of other cheap microfibers). I did clay the car the weekend I bought it. Clayed and sealed it actually. So, hopefully that's not the issue. All good points, thank you.
Nice... might actually give them a shot first! Then if I don't like them, I'll try the expensive ones!
Old 07-21-2014, 04:45 PM   #12
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
I will second the "Rag Company", reasonably priced and I have no issues with them.
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 07-21-2014, 05:36 PM   #13
Forte
Forte's Avatar
Drives: 2011 2LT/RS CGM W/ Black Stripes
The Griots Garage towels you used, were they soft blue ones?
Forte is offline   Reply With Quote
Old 07-21-2014, 07:18 PM   #14
67RS2010SS
67RS2010SS's Avatar
Drives: Maroon 67 rs and CRT 2012 ZL-1
Always find it funny spend $50,000 on a car and clean it with $2 microfiber towels?
" No matter how tough you are when a 2 year old hands you a toy phone you answer it"
67RS2010SS is offline   Reply With Quote
