09-24-2014, 11:48 AM | #1 |
Drives: 2012 camaro 2lt/black Join Date: Sep 2014
zl1 muffler
hey guys
just got a stock zl1 muffler from a friend of mine, I wanna them on my 2lt Camaro, but when I checked them, I found out there is a thing on the one of the pipe like a switch thing, and there is no wire, nothing on it, my question is how do I get that thing open or close, do I need any wire to control it? |
09-24-2014, 11:55 AM | #2 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
It's the solenoid for the flap that blocks the exhaust from going through the muffler via the inner pipe. With nothing controlling it the all the exhaust will flow straight through the outer pipe. A lot of us have pulled the fuse to make it work like that anyway. You could probably wire a relay to it controlled by IGN to keep it closed if you wanted.
09-24-2014, 12:03 PM | #3 | |
09-24-2014, 12:04 PM | #4 | |
09-24-2014, 12:18 PM | #5 |
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z Join Date: May 2009
It's engaged with a 10 amp fuse. Personally I'd consider just leaving it out or get an aftermarket "Mild to Wild" controller to hook it up with a wireless key fob.
If your getting a loud drown sound while cruising at highway speeds you might want to hook it up and see if it will quiet the exhaust especially for long trips.
- Buttons and Skulls -
miss my annimated signature. |
09-25-2014, 07:17 AM | #6 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Just put them in, the actuators are controlled by vacuum. You can just run a long vacuum line from the engine bay to the actuators, just have to use a tee in the rear. Then the flaps will be closed at idle and part throttle, then open when get to about 3000 RPM or so. No electrical needed if you do it that way. If you want full control, then it is still similar, there is just a solenoid box that you would have to get to control it, but the box is about $200. I built my own for quite a bit less.
09-25-2014, 08:46 AM | #7 |
Drives: 64vette,2010 2SS,2013 Zl1 Join Date: Mar 2013
Your explanation is somewhat right. The actuators are control by vacuum but without 12v, they will be open all the time, wild, the solenoid controls the vacuum by grounding or opening the I/p to the solenoid. Once you got vacuum, ground the I/p pin to the solenoid, you get mild. open and you get wild. The automatic on/off is controlled by the fuel pump control module which put a ground or not and its under control of the engine control module.
09-25-2014, 09:02 AM | #8 |
Your explanation is for a factory NPP car. I explained for a retrofit, which the OP is asking about. I have retrofitted multiple non factory corvettes.
