![]() ![]() Drives: '12 2SS/RS 45th vert, '14 2SS/RS Join Date: Nov 2013
Where to pass through the firewall
I have a train horn set mounted behind the lower grille of my ZL1 fascia. I am mounting the tank and compressor in the trunk. I have 50' of 1/2" D.O.T. airline to work with. If I bring it under the carpet through the cabin, where can I pass through the firewall to get under the hood?
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
look under hood on the drivers side.
find where the battery cable comes through (next to the master cylinder) about 2 inches above the battery cable is a hole with a plug in it. you can't really see it but you can feel it, push that plug out. then pull back the carpet in the footwell and find it. its probably a 5/8" to 3/4" hole. |
