Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 11-06-2014, 01:06 PM   #1
stev15
stev15's Avatar
Drives: Lemans Blue with White stripes
small oil leak
I have small amount oil coming from long oil stem that goes into the crossram manifold.What best way to take out or can it be tighten?
stev15 is offline   Reply With Quote
Old 11-07-2014, 09:52 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
Do you have a picture of the area that is leaking? It would be helpful in getting you the proper response.
TheHorse13 is offline   Reply With Quote
Old 11-07-2014, 09:14 PM   #3
stev15
stev15's Avatar
There picture of the motor in my album.it the long chrome stem with oil cap on top.It leaking where stem goes into manifold.
Old 11-12-2014, 02:41 PM   #4
TheHorse13
TheHorse13's Avatar
The oil filler tube is not screwed in, rather, it's seated in place with force.
You can remove the oil cap, take a block of wood and place it over the top of the filler tube and tap it with a hammer. Do NOT go crazy and beat the tube down into the manifold.
If this technique fails, you may have to replace the tube with a new one. The new filler tube will need to be installed with the method described above.
Old 11-14-2014, 01:15 PM   #5
stev15
stev15's Avatar
Think i solved the problem,I bought new oil cap it fits alot tighter.Drove car around seem to be working.Need to take longer ride to be sure.Thanks for your advice.
