Emblempros
Old 01-14-2015, 01:47 PM   #183
Fish-man
SS HWSE
Fish-man's Avatar
Drives: too many to say!
is the coil reloc mandatory? or can you modify existing?
Fish-man is offline   Reply With Quote
Old 01-14-2015, 01:51 PM   #184
hammdo
'It's an experiment'
hammdo's Avatar
You can modify the existing. I wanted to use a relocation bracket vs upgrading the valve covers.
-Don
hammdo is online now   Reply With Quote
Old 01-14-2015, 03:24 PM   #185
Fish-man
SS HWSE
Fish-man's Avatar
-Don
ok, so LS3/l99 valve covers with a modified oe coil bracket would work?
Old 01-14-2015, 03:59 PM   #186
hammdo
hammdo's Avatar
yep, I have the L99 valve covers, you can just drill a new hole above the current hole in the coil bracket to lower it about a half inch -- that would do it...
Old 01-14-2015, 04:12 PM   #187
hammdo
hammdo's Avatar
OK, SC Upper Lid is ON!
I did NOT have to drop the cradle. I was able to use these tools to tighten all the bolts:
Now my hands were able to get on all the bolts behind the lid. I was able to use the ratchet wrenches to get the bolts tighten -- except the two (# 15 and 16 shown below) in the middle back -- that I used the socket, extension and swivel to get that done!
Of course torqued all the ones I could get to, and tightened the others 'good n tight' to make sure they were on.
To get to the very back two bolts (# 15 and 16) I used a hammer handle to give me just a little bit more room:
Its rubber so I was able to wedge it under the cowling just enough for the ratchet and socket to do its work!
So the specs:
Used vacuum grease to ease the lid -- just on the outer edge of the lower manifold where the green gasket sits:
Installed the intercooler gasket -- NOTE the orientation!:
It can only go on one way -- good too!
Now, I put the bolts on the lid as there are 'holders' to keep them in place (the lower manifold has them too, but I was too paranoid). VERIFY the green lid gasket is on (Mine was):
Ready to go!
Now, to get to the back bolts, I remove 2 cowling pins as they hit my hand while tightening the screws:
Waa-Laa -- Lid is on!
All tight and good to go! Followed the tightening sequence in the manual
44 inch lbs (First Pass)
89 inch lbs (Second Pass).
Good thing my hands are a little smaller ;o)
More to come...
-Don
Old 01-14-2015, 08:35 PM   #188
62nalide
62nalide's Avatar
Drives: 2013 SS
Sweet!!!!
62nalide is offline   Reply With Quote
Old 01-14-2015, 08:46 PM   #189
hammdo
hammdo's Avatar
Work keeps getting in the way ;o) Need the time!
-Don
Old 01-14-2015, 11:45 PM   #190
hammdo
hammdo's Avatar
Getting the brake booster hose (came with the kit), coil packs (kept the originals -- they will get me running until the relo kit gets here) and map sensor (with longer wire that I added) going:
Need to get the headers, O/2 sensors, and exhaust on before getting to far on the top end...
Will be starting the heat exchanger tomorrow...
-Don
Old 01-15-2015, 10:39 AM   #191
hammdo
hammdo's Avatar
Someone asked what I did for the existing coil brackets; I drilled a hole above the existing one so it would give the injector wires some clearance:
-Don
Old 01-15-2015, 06:57 PM   #192
hammdo
hammdo's Avatar
Well, the exhaust parts came in so I'll get that started and hopefully, get those done by tomorrow!
Have the O/2 extensions installed on driver and passenger side now:
Drivers:
Passenger:
Coil Pack on Passenger's side:
Getting closer!:
-Don
Old 01-15-2015, 07:16 PM   #193
Fish-man
SS HWSE
Fish-man's Avatar
Do like!
Old 01-15-2015, 10:06 PM   #194
hammdo
hammdo's Avatar
Belts are on.
The one that came in the kit was too short so I had to go and pick-up one that did fit:
O'Reilly's had it...
Since the tensioner and pulley on the snout are 8 ribbed, I had to move the belt in 1 rib so it would line up correctly:
Looking nice!
Still more to do to get it ready -- Heat exchanger, the exhaust, hose routing, still a bit to do, but I can see the light @ the end of the tunnel...
-Don
Old 01-15-2015, 10:32 PM   #195
Fish-man
SS HWSE
Fish-man's Avatar
Does the tensioner show you the optimum operating range?
Old 01-15-2015, 11:06 PM   #196
hammdo
hammdo's Avatar
No, it sets the tension once I take off the tool. It's pretty tight...
