Old 01-09-2015, 06:58 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
ZL1 brake fluid?
After washing the car today I checked all the fluids and I noticed the brake fluid looks fairly dirty. Car only has 5000 miles on it but I know the SS guys are having all kinds of issues with dirty brake fluid messing up their clutch master cylinders.
I used Motul 600 when I upgraded my V6 car with brembos. Worked great.
Should I just have the system bleed at the dealer and swap it to Motul 600?
I saw this the other day:
http://www.hennesseyperformance.com/brbrflsp50.html
Brembo 500++ brake fluid? Anyone try this at all?
And has anyone separated their clutch fluid from their brake fluid reservoirs?
Mods:
Old 01-09-2015, 08:45 PM   #2
MTCobra
Drives: 2014 ZL1
I bled mine with Motul 600 2x now in ~3000 miles...a must for putting the car on the track.
2014 ZL1
MTCobra is offline   Reply With Quote
Old 01-09-2015, 09:21 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
motul 600 or 660 is best
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-11-2015, 12:47 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Anyone separated their clutch reservoir yet on the ZL1?
Mods:
Old 01-11-2015, 12:49 PM   #5
MTCobra
Drives: 2014 ZL1
Nope. With all the different opinions I've not messed with it. I only have 4 track days on it so far though.
2014 ZL1
Old 01-11-2015, 12:53 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
2014 ZL1
Ya I agree. I think I'll just make sure to change the fluid often and take a "don't fix it until I notice a issue" approach.
Mods:
Old 01-11-2015, 02:33 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
I use this in all my cars that see track time for both the clutch and brakes.
http://www.wilwood.com/Images/BrakeF...%20PLUS-lg.jpg
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 01-12-2015, 07:37 AM   #8
vatechguy3
Drives: 2014 ZL1 M6
same question here.
I was thinking about doing this in the spring. I am surprised there is not more discussion on this topic.
Tony
2014 ZL1 M6
Bone stock, for now!
2001 Z28 M6
!cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB
!4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link
ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance
OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners!
352rwhp and 366rwtq
vatechguy3 is offline   Reply With Quote
Old 01-12-2015, 09:45 AM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Originally Posted by vatechguy3 View Post
same question here.
Tony
I think the issues has come up with the 1LE guys more as they seem to track more. Most peeps who get the 1LE package do so for the additional corning during track days. I've seen very few ZL1's on the track the 4-5 times I've gone.
So the question is will the ZL1's suffer from the same clutch/brake fluid issue as the 1LE's?
I assume so as it appears we have the same clutch/reservoir set up.....
Mods:
Old 01-12-2015, 10:24 AM   #10
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I use motul 660 and I have seperated the clutch and brake reservoirs. The stock GM clutches put more contaminants into the fluid than the brake system does. The hard braking tends to leave the heated fluid close to the calipers so if you just bleed off a little from each wheel after each track day your brake side stays really good. Drag racing seems harder on the fluid than anything.....but I'm burning up clutches and transmissions.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
